interconnect question
pmckeealaska
I'm waiting on some AQ Diamonback interconnects from the cable swap program and have a quesiton about hooking them up. Should I concentrate on the connection between my reciever/pre-amp and my amp or the connections from the pre-amp to the DVD/CD player? Since I'm only getting a single pair to play with, I wanted to know which areas people concentrate on while testing new cables.
Music and Movie Rig
Samsung 40" HDTV 1080p
LSi25 Front Speakers
LSiC Center Channel
LSiFX Surrounds
Rotel RB 1080 2-Channel Amp
NAD T763 Reciever
Denon DVD 2900 Universal Player
Audiosource 10 Band Digital Equalizer
Audioquest CV-8 speaker cables
Audioquest Sub-X subwoofer cables
Audioquest King Cobra Interconnects
Monster AVS 2000 Voltage Stabilizer
Playstation 3 120GB Slim
LSiC Center Channel
LSiFX Surrounds
NAD T763 Reciever
Post edited by pmckeealaska on
Is there any way you can hook the DVD straight to the amp? It would be better, if you don't have a choice, to go from source to pre/receiver if you can't hook directly to the amp; your goal is to limit the varibles as much as possible--but its not always practical.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
Try it both ways and see if it makes a difference. It usually does.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
When comparing interconnects I always use a Denon stereo receiver for the very reason that steveinaz mentioned. Unless you have two sets of the same interconnects it is hard to tell where the differences are coming from when using a source, pre, amp combo."Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
Forgive the neophyte question, but don't you need to have the DVD player connected to the pre-amp in order to play music? Would I be able to play music by connecting the DVD player directly to the amo and bypassing the reciever/pre-amp? Hope I'm not being confusing.Music and Movie Rig
LSiC Center Channel
LSiFX Surrounds
NAD T763 Reciever
Playstation 3 120GB Slim -
You can connect a source directly to your amp provided either your amp or your source has an output control (volume/level adjustment). Of course make sure the volume is all the way down before hitting the play button....essentially you're using your output knob as a volume knob.
The reason I recommend this, is that you'll only have 1 set of interconnects in the chain, and it's easier to evaluate any changes/improvements.
You could also simply connect your speakers to your receivers speaker outs (therefore bypassing the amp all together), connect the source with the interconnect your evaluating, and be good to go as well.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2 -
Just to state the obvious (everyone needs a hobby), if you take you pre-amp out of the equation, you have to baseline listen with your usual interconnects...More later,
Tour...
Vox Copuli
