Subwoofer?
Pinktulip7
I need some advice to buy a new subwoofer,I am not getting enough bass from current one..
TV :>Panasonic TC-P55VT50
RECEIVER :> HARMAN KARDON AVR 7300
FRONT :> L & R :> POLK RTI A9 500 W
AMP :1> PARASOUND HALO A21 250 W
AMP :2> EMOTIVA UPA-1 200 W
CENTER :> POLK LSiM 706c 250 W
SURROUND SIDE :> POLK RTi A3 150 W
SURROUND REAR :>POLK FXI A6 150 W
DVD PLAYER(HD) :>TOSHIBA HD X-A2
DVD PLAYER(BLU-RAY) :>Panasonic DMP-UB900
POWER CONDITIONER :> PANAMAX M5400-EX
SUBWOOFER :A> SVS SB16-Ultra 1500 W Front
SUBWOOFER :B> SVS SB16-Ultra 1500 W Rear
Post edited by Pinktulip7 on
What is your budget?
SVS is a forum favorite, but HSU, and Dayton(inexpenisive) are viable solutions.Tschüss
Zach -
$500.00?TV :>Panasonic TC-P55VT50
SUBWOOFER :B> SVS SB16-Ultra 1500 W Rear -
Again, might I recommend the SVS PB 10 ISD. This thing hits hard, hits low, and is tight and accurate w/ music and movies. Return of the King and Master and Commander are true experiences with this thing in play. Sounds like you have an excellent setup right now.
If your budget is $500, the PB 10 is absolutely your best option. Nothing else at that price can even come close. Don't know your room size, but I have an average sized living room with two large openings to other areas of the house, and the sub shakes the room from the ground up. Truly the best entry level sub I've experienced. Don't listen to dealers who tell you to spend $800 on a Def Tech cube or an Earthquake sub. Go for SVS and never look back.
Check out the sub here.
Click the link to the review to check out an excellent review by Ed Mullen, known as Dr. Spec here on the forum.Current System:
CSi5-Center (for sale**)
FXi3-surrounds (for sale**)
Martin Logan Depth-Sub
B&K AVR 507
Pimare CD21-CD Player
Denon 1815-DVD Player
Panamax M5500-EX-Line Conditioner -
How about Polk?TV :>Panasonic TC-P55VT50
Here are some specs on the bigger Polk Subs, and the SVS PB 10 ISD. The SVS is within your budget, and clearly wins out over Polk in the frequency range.
Polk PSW 505-$500.00
Overall Frequency Response
23Hz - 160Hz
Lower -3dB Limit 28Hz
Upper -3dB Limit 125Hz
Polk PSW 12-$350.00 + shipping
26Hz - 200Hz
Lower -3dB Limit 33Hz
Upper -3dB Limit 160Hz
SVS PB 10 ISD-$470 Shipped to your door
# Proprietary SVS-designed long-throw 10" woofer
# 300 watt BASH digital switching amp
# Computer aided cabinet design with 1" front baffle
# Front-firing design with flush fit woofer and vent
# Patented 3" wide-flare port fittings
# Six removable, compliant floor isolation points
# Four finish choices to match any dCurrent System:
B&K AVR 507
