In wall Wire...What Gauge?
epjohnson
At that stage in basement HT room to run wire... also building bar area outside of HT for 2 channel set-up (will house in wall polks).
Any advice as to which gauge wire to run for these 2?
New to site...was reading thru many threads but I keep getting sidetracked... INFORMATION OVERLOAD!
______________________________
Sony 57 HD WS
Yam RX-V650
RTi6
FXi3
CSi5
YST-SW315
Monster HTS 2600
Sony 57 HD WS
Yam RX-V650
RTi6
FXi3
CSi5
YST-SW315
Monster HTS 2600
Post edited by epjohnson on
I second the Thug...Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
12 alittle overkill for that application? I would say 14 guage for long runs and 16 for short runs.... IMOMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
but why? When is having thicker speaker wire bad? Less resistance over longer runs... how is this a bad thing?Never kick a fresh **** on a hot day.
Thanks for the info... was leaning in the direction of 12/2 anyway, but wanted other's take on situation before laying out
How versed are you guys in DVD/DVR HD stuff?
posted a thread re: units available to upconvert to HD
quality that also have hard drive.______________________________
Sony 57 HD WS
Yam RX-V650
RTi6
FXi3
CSi5
YST-SW315
Monster HTS 2600 -
where did i say it was bad? I simply stated its overkill for external speakers or surround "type" applications, shoot run 8 guage if you think bigger is better... In the grand scheme of things 14 -16 is always reccomened for smaller or surround type speaker applications... except extremly long runs over 100 or more feet on a single speaker,MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
The 12ga is overkill, I have 14ga for my inwalls installed by Tweeter, and that may also be overkill. I saw a professionally installed whole house system with Paradigm speakers. The boathouse had 4 Stylus 350's on it, and they were at least 120 feet (straight run) from the AMP. So the total wire length would probably have been no less than 150 feet and 16ga was used.
Since Tour has not posted this link already, I'll fill in for him: Wire Guage GuideTschüss
Zach -
That last bit of info was extremely helpful... especially since all of my runs are under 50'.______________________________
Sony 57 HD WS
Yam RX-V650
RTi6
FXi3
CSi5
YST-SW315
Monster HTS 2600 -
LOL... Thanks, Zach... You interested in a personal secretary position?
epj,
Welcome...
Note that the table is stating minimums. When going in-wall you've got one shot, so consider bumping up a guage, and even pulling second runs for bi-wiring.
Even if your first installation cannot take advantage of the install, one down the road may be able to...More later,
Tour...
Vox Copuli
Originally posted by dbournival
The 12ga is overkill, I have 14ga for my inwalls installed by Tweeter, and that may also be overkill. I saw a professionally installed whole house system with Paradigm speakers. The boathouse had 4 Stylus 350's on it, and they were at least 120 feet (straight run) from the AMP. So the total wire length would probably have been no less than 150 feet and 16ga was used.Never kick a fresh **** on a hot day.
