Subs and Stuff!
sabbeth
Play it LOUD!!!
Cheers...sabbeth
Cheers...sabbeth
Post edited by sabbeth on
I would probably get a Y adapter. I don't know if it makes a difference or not, but that's what I use. Most better sub cables come with one.
You don't have to always set anything to small. It depends on your speakers. If your fronts are large enough and can handle the bass (30hz or so), set them to large.
Don't sweat the system. Just enjoy it. And of course dedicate every waking minute and available penny to better it like most of us do.Make it Funky!
Hi:
The dual rca input on the sub is for the dual voice coil. Use a Y adapter from your receiver.
Enjoy what you have, unless you have had to do with less, you will not appreciate more. Did I really think of that?
Gary -
Wow even I was impressed with that last post.:)
It reminded me of those "Jack Handy" skits on SNL.....what was it "Deep Thoughts"? -
my HSU vtf-2's manual recommends using a 'y' adapter because the signal strength is stronger when using the adapter which will help keep the subwoofer from going into standby mode. i believe your 250 has this same 'auto' on/off mode as the HSU. setting all speakers to small will route the bass singal (anything below 80hrz) to your subwoofer, aiding in better bass management. personally, i would play around with your settings, and see what sounds better to you. i use to set my 800i's to large, but now that i am running dual HSU's, i prefer them set to small. it's mostly a preference thing, not a set-rule. i love my rt800i's and would reccomend them highly! don't know what you are looking to spend, but these can be had for around $600, or even less right now. no need to be embarrased of what you own, at least you are on your start of an endless quest fo 'better' sound...
enjoy what you have, and when or if you want to spend more, go for it!!!.
welcome to the forum...:D
