hk 330 multi room set up ?
doubled
Hey polk folk,
I found a deal on a HK 330 demo unit to replace my sony 945. I've attempted to try and have the multi room speakers set up power my 150's to no avail. They work fine in 7.1 mode, but I can't get any sound while in multi room mode. I've followed the instruction booklet and have gone to the OSD field and changed the settings accordingly in the "multi room" and "advanced" settings. I have also set it to "on" using the "m-Room" buttom and still nothing. Being a demo, I did not receive anything to plug into the "multiroom audio ouput". Is that my problem, or am I missing something?
Thanks,
doubled
Thanks,
doubled
RCA 52 something or other
Sony STR-DE945
CS245i (center)
RTi 70 (A speakers)
RTi 150 (B speakers)
RTi 38 (surround)
PSW 202 (sub 1)
PSW 250 (sub 2)
Rogers Hi-def/5.1 digital cable
Direct TV Hi-def/5.1 satalite
Zenith DVD
Sony STR-DE945
CS245i (center)
RTi 70 (A speakers)
RTi 38 (surround)
PSW 202 (sub 1)
PSW 250 (sub 2)
Zenith DVD
Post edited by doubled on
Does your receiver have an amp section for the multi-room feature. Most multi-room receivers require and additional amp to power the extra set. Check your manual and see if you need that additional amp.
Everytime I think I'm out, THEY PULL ME BACK IN!!!!!!
Polk 70's,40,30's
Velo DLS 3500 Sub
JVC 61" HD-ILA
Sony DA4ES AVR
Oppo 981 DVD
Sony CDP-CX235 CD
Signal Bi-wires
AR ProII IC's -
actually, these days, 7.1 receivers with multizone already will power the second zone by using the 6th and 7th channels of internal power.
Sounds like everything is done right, but I'd contact HK.Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
On my hk 630 there were two or three places in the osd
speaker settings - I think you have to set that you have surround back/multi-room speakers
Advanced - switch the surround back to multi room
Multi room - set multi-room on and select an active input and turn up the volume for the second zone.
Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70 -
Thanks guys, I appreciate you taking the time to try and help. I've placed a call to Future shop where I purchased it, and they can't help. So I'll pose the qustion to Hk themselves. I've never posted a thread here before, but have been reading you guys for a couple of years now, and have been amazed of the knowledge on this forum. Keep up the great work, you guys have taught me a lot over the years.
Rock on!!RCA 52 something or other
Sony STR-DE945
CS245i (center)
RTi 70 (A speakers)
RTi 38 (surround)
PSW 202 (sub 1)
PSW 250 (sub 2)
Zenith DVD -
After upgrading from a bargain basement Sony AVR I ASSUMED that 4ES also needed an external amp for multi-room. After reading your reply Toxis, I actually checked my manual and I can use the unused amps for multi-room. Thanks Toxis:DEverytime I think I'm out, THEY PULL ME BACK IN!!!!!!
Polk 70's,40,30's
Velo DLS 3500 Sub
JVC 61" HD-ILA
Sony DA4ES AVR
Oppo 981 DVD
Sony CDP-CX235 CD
Signal Bi-wires
AR ProII IC's -
In multizone you can't have 7.1 because you are using the surround back amp for the other zone. You stated that it worked in 7.1 it should be 5.1 with multizone.Arcam DiVa AVR300 Receiver
Outlaw Audio 755 Power Amp
Audio Tecnica lp120 Turntable
Polk Audio LSi15 Front Speakers
Polk Audio LSi9 Rear Surrounds
Polk CSi2 Center Speaker
Apple Mac Mini HTPC
Samsung HL67A750 TV -
Hi devo220,
Thanks for posting. I stated it worked in 7.1 just to show that there was power being sent out to those speakers. So when I switch from 7.1 to 5.1/multi room then I would expect the former back surround to to now receive multi room power.RCA 52 something or other
Sony STR-DE945
CS245i (center)
RTi 70 (A speakers)
RTi 38 (surround)
PSW 202 (sub 1)
PSW 250 (sub 2)
Zenith DVD -
glad to be of service. It's a lil feature that most people don't even know about.Originally posted by Maurice
Just as an FYI, here is the response I received from HK;
"Hello,
Please note that Multiroom will only function if the source in connected
VIA analog inputs. Therefore if the source is a DVD connected via an
optical cable, you would also have to connect a set of RCA cables.
Take care,
Donny Coffin
Marketing Coordinator
Erikson Consumer
1-800-567-3275
Ph: 514-457-2555
Fx: 514-457-0055"
I would have never figured that one out.RCA 52 something or other
Sony STR-DE945
CS245i (center)
RTi 70 (A speakers)
RTi 38 (surround)
PSW 202 (sub 1)
PSW 250 (sub 2)
Zenith DVD -
Interesting... I've been selling HK for over a year and a half and never knew that. Thanks for the tip! I need to check out Onkyo and Denon to see if they're the same way.Never kick a fresh **** on a hot day.
