Rear Speaker Height
OK, here is a question for you all. I want to finalize where to mount my FXi5's before I rip holes in my walls. At what height do I put these from the floor? I have heard the bottom of the speaker should be at the top of your head where your sitting. I have heard they should be at 2-3 feet above the top of your head when sitting. Please give me your opinions. Regards
RXV1400 Yamaha Receiver
Polk RTi10s front
Polk CSi5 center
Polk Fxi5 Rear
Polk PSW505 Sub
Denon 1600 DVD
Direct TV HDDVR
55" Mits HDTV
Polk RTi10s front
Polk CSi5 center
Polk Fxi5 Rear
Polk PSW505 Sub
Denon 1600 DVD
Direct TV HDDVR
55" Mits HDTV
Post edited by KLD2246 on
Thanks Frank. I will set them up like you stated. Great article by the way.RXV1400 Yamaha Receiver
Polk RTi10s front
Polk CSi5 center
Polk Fxi5 Rear
Polk PSW505 Sub
Denon 1600 DVD
Direct TV HDDVR
55" Mits HDTV -
I should also add that the speakers should be slightly behind the listener. Get some step ladders to use as temporary stands before picking the final location.
