LSI and Sunfire AMP Bi-wire-Spit wire ??
ChicagoMike
I just bought:
LSI9's
LSIC
LSIFX
I already own:
Harman Kardon DPR 2005 AV reciever
Sunfire Sig 425 watt 5 channel amp
I am trying to determine how to wire the speakers to the amp. I do understand that its up to my taste, BUT, does anyone have any recomendations??
The Sunfire amp has voltage source and current source terminals for bi-wiring on the amp side. The LSI's also have bi-wire capability.
Here is the manual for the amp if its helpful. the bi-wire section is on page 18.
http://www.sunfire.com/pdf/Cinema%20Grand%20and%20Signature%20Series%20II%20Architects%20Choice%205-Channel%20Power%20Amplifier%20Manual.pdf
Option 1 - Bi-wire - 2 to amp 4 to speakers
Option 2 - Split wire - 4 to amp 4 to speakers
Option 3 - standard hook up 2 to amp 2 to speakers
Im buying some new speaker wires and want to get some feedback before I spend the $$ on new cables.
LSI9's
LSIC
LSIFX
I already own:
Mike
Chicago, IL
Chicago, IL
Post edited by ChicagoMike on
Here is the correct URL for the sunfire manual. The biwire section is on page 18.
http://www.sunfire.com/pdf/Cinema Grand and Signature Series II Architects Choice 5-Channel Power Amplifier Manual.pdfMike
Chicago, IL -
One more time with the link... hope this does the trick.
http://www.sunfire.com/cinemagrandsignature.htmMike
Chicago, IL -
From what I've gathered, it's recommended that you connect the voltage (tighter-sounding) source to the mid/bass driver section, and the current (warmer-sounding) source to the tweeter section for the two mains. If this sounds a bit too laid back, you can simply combine the connections at the amp end to the voltage source output. Either way is functionally the same. I think that the currrent source outputs were included to cater to two-channel listeners who prefer a warmer, more 'tube-like' sound.Polk LSi9 Mains, Polk LSIC Center, Polk RT25i Surrounds, Polk M3II Rear Surround, SVS PB10-ISD Sub, Denon AVR 2809 (as digital pre/pro only), Sony BDP-S350, Oppo DV-981HD, Cambridge Audio Azur 540C (CD), Marantz MM9000 5-ch amp, Outlaw ICBM, Panasonic th-42PX85u HDTV, Behringer BFD Pro, Monster Power HTS 2600 Conditioner
That's pretty much it...
I love the current output to my SRS's SL2000 tweeters. It really refines/ softens this tweeter. The MW's get the voltage output. The current output to MW's is a bit too soft.
With the 9's, which I think are already laid back on the upper end, I could see preferring voltage all the way around...
The Sunfire Sig Cin Grands with their 5-way, binding post layout almost demand the use of banana plugs. Added benefit is it makes swapping them around a snap and so you can play.
Have fun...More later,
Tour...
Vox Copuli
