kicker comp cvr
Systems
i got a Profile AP1000M amp and a Kicker Comp VR 03CVR124 in a 1.75 cubic foot q-logic box now what im wondering is what should i set my amp at with the remote.now last time i had this sub i had it in a 1.25 q-logic box and it sounded better so im orderin some poly fill to put in it.anything would be helpfull
Testing
Testing
Testing
Testing
Testing
poly fill will make the box seem bigger too the sub. If your tying to make it smaller (since you say your last was in 1.25) adding polyfill is the wrong way to go.
Sounds like a lot of power for 1 sub...not familiar with that amp though
