Subwoofer for current setup
PCBiker
PCBiker Posts: 11
edited February 2005 in Speakers
I have the following speakers:
RTi12 - Mains
FXi5 - Surround
CSi3 - Center (Free with the FXi5s...)
I've been looking at the Polk Subwoofers but it seems that there may be better models available for the same price. (I've been looking at the PSW505)
Does anyone have any recommendations for my current setup?
Thanks in advance.
RTI12 - Main
FXI5 - Surround
CSI3 - Center
Subwoofer - Coming soon
Post edited by PCBiker on
    VR3 Posts: 28,776
  • danger boy
    danger boy Posts: 15,722
    there is nothing wrong with Polk subwoofers. for the money.. they play pretty loud. They aren't the best on the market. but they ain't half bad either. I think most people in here started out with a Polk subwoofer in the beginning. I surely did.
    After using the Polk subwoofer for about 2 years I longed for something a bit more lower bass. So i went with a SVS 20-39PCi round subwoofer. It's much better than the Polk i was using.
    Don't shy away from the Polk subwoofers. But if you want something that slams deeper.. then there are other choices out there.
    the system you are building.. looks and should sound really very good. Those RTi12's should rock your house quite nicely. ;)
    PolkFest 2012, who's going>?
  • PCBiker
    PCBiker Posts: 11
    Thanks for the information. I lucked out and found the RTI12's at Circuit City when they were phasing out the RTI line. (Thanks to information provided by others on this forum)
    I hope to eventually have a 7.1 setup....but I think I'll get the subwoofer first and then upgrade my receiver.
    Thanks again!
    RTI12 - Main
    FXI5 - Surround
    CSI3 - Center
  • Toxis
    Toxis Posts: 5,116
    It all depends on what you're looking for. How will you be using it? What kind of room are you in? All HT or also music? What's your budget? How particular are you about the music or are you more HT oriented? What kind of receiver do you have and how is the bass management on it? So many unanswered questions. Typically though, people here will tell you to just get an SVS which is not a bad decision. There's a lot of good subs out there.
  • PCBiker
    PCBiker Posts: 11
    You're right I should've included more information in my original post. I'll be using my setup mainly for HT but also music from time to time. My room size is is approx. 600 square feet. Budget wise I like to buy something that will last.
    Mainly I just wanted to make sure that when buying a sub matching is not as critical as the surrounds.
    Thanks again
    RTI12 - Main
    FXI5 - Surround
    CSI3 - Center
  • Early B.
    Early B. Posts: 7,900
    For a room that size, you're gonna need one helluva sub. So get the biggest, baddest sub you can afford. Another option is to get a decent sub, and also buy a separate amp for your RTi12's since they produce a good amount of deep bass.
    "God grooves with tubes."
  • GaryZ06
    GaryZ06 Posts: 317
    I have almost the same setup as you and I just got a Velodyne DLS-5000R......I am very happy with it and for the money($799 msrp)....I paid $720+tax ....it is a awesome bang for the buck.It is a very good looking sub....gloss balck front.
    Panasonic 50" Plasma + Pioneer 6010
    Toshiba XA2 HD-DVD
    Panasonic BD30 Blu-Ray
    Pioneer 1014
    Polk RTi12 (front)...Polk CSi5 (center)
    Polk RTi4 (rear)...Velodyne DLS 5000-R Sub
    3 Outlaw M-200 Amps
  • PolkThug
    PolkThug Posts: 7,532
    Yeah, that's a big room, I'd look at the dual 12's that SVS has to offer.
    PB12-ISD/2 or PB12-Plus/2
    http://www.svsubwoofers.com/subs_pb12_isd_2.htm
    http://www.svsubwoofers.com/subs_pb12_plus_2.htm
  • danger boy
    LQQKIN good GaryZ. very nice set up.
  • GaryZ06
    GaryZ06 Posts: 317
    Thanks danger.....Almost done ....gonna get 3 Outlaw M200 monoblock amps for the 3 front channels....that should kick...
    Toshiba XA2 HD-DVD
    Pioneer 1014
    3 Outlaw M-200 Amps
  • PCBiker
    PCBiker Posts: 11
    GaryZ
    I'm glad to hear that you like your Velodyne sub. I was beginning to look at some of their products.
    Nice setup...our HT setup is similar except....
    You have the CSi5, a nicer TV, a sub, ah well....some day!
    Thanks for the information!
    RTI12 - Main
    FXI5 - Surround
    CSI3 - Center
