Mitsu. remote...Denon dvd...HELP!
gwh
gwh Posts: 1,451
edited February 2005 in Electronics
Picked up a Denon DVD 2200 and my Mitsubishi remote will not operate it.
Remote came with my Mitsubishi TV(MITWS48311) it has one code for a Denon dvd player but it does not work. The remote does control my Denon 3803’s on/off and volume fuction(different code). Seems to me it should control the dvd player also.
I know I’ve done it right, got the receiver to work.
Bought the television 11-09-02.
Please share some knowledge.
Thanks,
G
HT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects.
Post edited by gwh on
    F1nut Posts: 52,005
    You'll need to get a universal learning remote......just the way it is.
