Need new Center Speaker
KLD2246
KLD2246 Posts: 42
edited February 2005 in Speakers
I have the RM7200's and push them with my RXV1400 from Yamaha. I want to use the current center and move to the rear center and really want to upgrade my front center. Do any of you have any suggestions. I want to stay with Polk. Thanks in advance.
RXV1400 Yamaha Receiver
Polk RTi10s front
Polk CSi5 center
Polk Fxi5 Rear
Polk PSW505 Sub
Denon 1600 DVD
Direct TV HDDVR
55" Mits HDTV
Post edited by KLD2246 on
  • KLD2246
    KLD2246 Posts: 42
    I searched around and found this should be the best fit for my system and circuit city has it for $299 so I will run over and get it. If anyone thinks differently, let me know within the next 3 hours.
    Polk RTi10s front
    Polk CSi5 center
    Polk Fxi5 Rear
    Polk PSW505 Sub
    Denon 1600 DVD
    Direct TV HDDVR
    55" Mits HDTV
  • okiepolkie
    okiepolkie Posts: 2,258
    Your selection looks okay, but only your ears will be able to determine if it will be a compatible speaker with the RM's.
    Let us know how you like the sound.
    Zach
    Tschüss
    Zach
  • KLD2246
    KLD2246 Posts: 42
    Thanks for the information. I called Polk and he told me that this center would do fine however if I am planning on upgrading to the monitors for front and back, then this would work real good together. In short, I guess I will wait until I get ready to upgrade
    Polk RTi10s front
    Polk CSi5 center
    Polk Fxi5 Rear
    Polk PSW505 Sub
    Denon 1600 DVD
    Direct TV HDDVR
    55" Mits HDTV
  • KLD2246
    KLD2246 Posts: 42
    I basically went crazy this weekend. Got the RTi10, the CSi5 and will wait on the rears after I can afford it. Wow, what a difference in sound. I will save my 7200 and use the sub and rears for now until I can get what I want.
    Polk RTi10s front
    Polk CSi5 center
    Polk Fxi5 Rear
    Polk PSW505 Sub
    Denon 1600 DVD
    Direct TV HDDVR
    55" Mits HDTV
