Digital coax question...
steveinaz
I'm seriously considering buying the Benchmark DAC-1 for my CEC and was wondering how good the digital coax needs to be? Would I be fine with a mid-grade ($50) cable? Can't see where cables would play to big of a part with a digital out?
Should I use the AES/EBU output instead?
Suggestions?
Suggestions?
Post edited by steveinaz on
I found big differences between the two digital coax cables I tried, a Harmonic Technology Platinum Cyber link cable and a less house brand by Moray James. I found the Moray to be a much much better cable, and the differences weren't sublte or something you had to sit and listen for. If you have a local dealer, you might want to grab a handfull of cables and see if you can't try them out at home.
I'd also look for a Museatex Bitstream DAC if you can find it, send it over to John Wright and let him mod it. You might be able to do it for the same price as the Benchmark. -
Cool, what about the AES/EBU? Should I take advantage of that output on my CD player, or would a coax be fine?Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
Yes! -
AES/EBU and XLR are one in the same, correct?Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
I'm seriously considering buying the Benchmark DAC-1 for my CEC and was wondering how good the digital coax needs to be? Would I be fine with a mid-grade ($50) cable? Can't see where cables would play to big of a part with a digital out?Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
I've seen some pretty incredible data on this thing and it looks like a winner. I've never used an outboard DAC though, nor have I ever had equipment with AES/EBU connections until my CEC CD Player. I'm curious if there's a benefit to using the AES/EBU since its available.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
http://cgi.audiogon.com/cgi-bin/auc.pl?dgtlconv&1109040575&auc&3&4&
Theres an auction right now for a BiDat, a step up from the bitstream, but who knows you might be able to get it at a steal. As for the balanced connections, I've heard conflicting reports about it.
Forgive me, but I find this all funny after all the speakers>source debates.
At anyrate good luck. Experiment with the cables, cost doesn't always reflect performance. -
There is a funny irony to the whole thing huh? LMAO!!! Sorry man, I still have tears in my eyes and my face hurts from laughing at the "owned thread" this morning. Funny stuff....Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
