Mid Volume Level
janmike
janmike Posts: 6,146
edited February 2005 in Electronics
How can I tell where the volume mid-point is on my Yamaha RX-V1500. There are no markings on the dial and the only sound level indication (-20dB...) is displayed on the front panel. I did not see anything in the manual to indicated a volume range. Thanks.
Michael ;)
NORTH of 60°
Post edited by janmike on
  • TheReaper
    TheReaper Posts: 636
    Switch your receiver to an unused input, so that you don't blow your speakers (note: If you want to be doubly sure that you don't blow your speakers, disconnect them). Turn the volume all the way down and get the lowest reading (mine is -81). Then briefly turn the volume all the way up (and then right back down) to get the highest reading (mine is +18).
    Remembering my high-school math, to find the midpoint between two values, add them together and divide by 2.
    For example my midpoint:
    -81 + 18 = -63
    -63 / 2 = -31.5
    so my volume midpoint would be around -31
    Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70
  • janmike
    Thanks. Boy do I feel stupid. Next time I'll think before I type.
    Michael ;)
    NORTH of 60°
  • hamzahsh
    hamzahsh Posts: 439
    Modern receivers and pre/pro use digitally regulated volume system which reads in db (decibals) increments
    -31.0 db is below REF level
    0 db is REF level
    +1.0 db is above REF level
    Enjoy safe listening!
    Panasonic TH-50PX80U Plasma HDTV
    Polk Audio RT800i (fronts)
    Polk Audio CS400i (center)
    Polk Audio F/X1000 (side surrounds)
    Polk Audio RTi6 (back surrrounds)
    Velodyne CHT-15 (subwoofer)
    Yamaha RX-V1400 (Pre/Pro)
    NAD C272 (2-ch Amp)
    Adcom GFA-7605 (5-ch Amp)
    Toshiba SD-3109 (DVD/CD player)
    Malata DVP-580 (Multi-region DVD player)
  • kberg
    kberg Posts: 974
    -81 + 18 = -63
    -63 / 2 = -31.5
    If you were using this method, wouldn't the mid-point be 49.5 (or about -49 on your receiver)? You need to consider the two numbers as absolute numbers and divide the difference between the two:
    -81 to +18 = 99 (absolute number)
    99 / 2 = 49.5 (so about -49 on the receiver would be your mid-point, right?)
    Mains: polkaudio RTi70's (bi-wired)
    Center: polkaudio CSi40 (bi-wired)
    Surrounds: polkaudio FXi30's
    Rear Center: polkaudio CSi30
    Sub: SVS 20-39 PC+
    Receiver: ONKYO TX-SR600
    Display: JVC HD-56G786
    DVD Player: SONY DVP-CX985V
    DVD Player: OPPO DV-981HD 1080p High Definition Up-Converting Universal DVD Player with HDMI
    Remote: Logitech Harmony H688
  • TheReaper
    By using the absolute values, you are comming up with the range 0 -> 99. The mid-point you got 49.5, is the mid-point within the range. You then have to add your range-mid-point to your actual zero point -81, to get your actual mid-point:
    -81 + 49.5 = 31.5
    By the way, that is the type of technique you would use if you wanted to calculate a percentage value (eg. 60%).
    *** oops *** edit delete
    *** oops abs(-81) + abs(18) = 99
    *** the mind gets slower as one gets older :)
    *** fixed below, should be the absolute value of the differance between the high and low, to get the range
    abs(-81 - 18) = 99
    .60 x 99 = 59.4
    -81 + 59.4 = -21.6
    so the 60% point would be around -22
  • gregure
    gregure Posts: 871
    I was under the impression that it was a bit more complicated than simply finding the 1/2 way point between min and max. After all, aren't most recievers now programmed to give you a lot more play in the lower volumes than higher? For example, the difference between -40 and -30 is not as much as the difference between -30 and -20. The louder you get, the more drastic the volume difference between each step up. If this is the case, like with Onkyo's, it is hard to find the 1/2 way point, as 0-60 only goes from silent to semi-loud, but 60-70 is semi-loud to way-too-loud, depending on the size of the room.
    Current System:
    CSi5-Center (for sale**)
    FXi3-surrounds (for sale**)
    Martin Logan Depth-Sub
    B&K AVR 507
    Pimare CD21-CD Player
    Denon 1815-DVD Player
    Panamax M5500-EX-Line Conditioner
    F1nut Posts: 51,776
    A simple way to find the level at which it is wise not to pass is this. Turn it up until the sound becomes shrill and compressed and that's it, any further increase will most likely result in unpleasant things happening. Of course, this will vary from recording to recording.
  • unc2701
    unc2701 Posts: 3,587
    dB is a log scale... +3dB is usually associated in doubling the perceived volume and +10dB is associated with 10x the volume. So a change from -40 to -30 would mean you go from, say, 1 to 10 watts output, but a change from -30 to -20, would give you a change from 10 to 100 watts output.
    It's a bit more complex than this, but in theory, 1/2 volume is 3dB below where your wife starts screaming "THAT'S TOO F---ING LOUD!!!"
    Backburner:Krell KAV-300i
