Back surrounds
What do you all recommend for a back-surround speaker, in a 6.1 setup (6ch amp only) that will be mounted on the ceiling?
Do you think a dipole surround like a FXi3/etc will work well for this?
Currently I'm using an old Cambridge center channel, and it actually works ok but the side surrounds have been disappointing ever since I moved into my new place, so I'm thinking of replacing them with ie. FXi3s and would like the back-surround to match (then all my speakers would be Polks too
Is that gonna work well or should I get a Polk center channel for the back?
- Sony 50"A3000 SXRD; Onkyo TX-SR 805
- Polk RTi150 mains; CSi30 center; FXi3 surrounds, R15 backs
- Velodyne CHT-12 subwoofer
Post edited by walk on
You will probably want to find some FXi30's or FXi50's to match your system if you want di/bipoles.
There are a couple of different ways to mount them to the ceiling. The 30's are a little lighter weight, so they would be preferred.
Will they be placed in front of, behind, or beside your listening postion?Tschüss
Zach -
Yeah they no longer make the 30's though. I've been browsing ebay but never seem to find any. Other problem is where to buy a single, since they are sold in pairs...
The sides are mounted well in front of the listening position. Unfortunately this is the only way to mount them. When I designed the room I had only a small 27" television and sat a lot closer, but since getting the 46" bigscreen I have to sit a bit farther back
Anyway that's why the dipole "angled" speakers would be great I think, they would face backwards.
The back is mounted on the ceiling about 3 feet behind the couch.- Sony 50"A3000 SXRD; Onkyo TX-SR 805
- Velodyne CHT-12 subwoofer -
You are looking for a single FXi30? Well, if you don't mind the shameless plug, I've been trying to sell a set of right channel FXi30's for a while now. I would give you a good deal on a single Here is the thread that I started to try and sell them: FXi30's.
Have you looked at www.audiogon.com for a set of FXi30's. I think there is a set on there right now.
A set of FX300i's might be okay too if you can find them.
Hope this helps.
PM me if you are interested.
ZachTschüss
Zach
