mmc650 in 6.75 door mount
knieght rieduz
knieght rieduz Posts: 7
edited February 2005 in Car Audio & Electronics
Hey guys, i have a set of polk mmc650s. i took apart my srt4 and tried to install them in the front door. they dont line up with the stock speaker mount nor does the ring that came with the speakers work. would this require custom fabrication or are there rings i can buy that will work?
thanks guys
Post edited by knieght rieduz on
  • exalted512
    exalted512 Posts: 10,735
    if you have any spare wood, preferrably mdf but plywood works too, just build a spacer that you can screw in to your door, then screw the speaker to the wood
    -Cody
  • MacLeod
    MacLeod Posts: 14,358
    Agreed.
    Just run down to your nearest Lowes and pick up a 1'x2' sheet of 1/4" MDF or birch plywood and build your own baffle.
  • knieght rieduz
    thanks for the help guys, i'll go try that out.
