thinking about an upgrade
kayo_michael
kayo_michael Posts: 1
edited February 2005 in Car Audio & Electronics
Hi, i am new to this forum. :)
I have 2 pairs of Polk MOMO MMC570's in my 95 Explorer.
It is powered by the built-in amp in my Panasonic CQ-C5410U head unit which is 25watts x 4 RMS (50w peak).
I am considering about buying a 4ch amp.
The reason is when i turn the volume up to about 70%, the bass becomes distorted and it sounds like crap. This is the amp getting pushed to the limit right? i mean, the speakers are supposed to be able to handle 80w(180w peak) each so they should be capable of producing louder music...
The C400.4 said something about a "perfect match" for MOMO speakers but i don't quite understand what they mean. :(
Would any other Brands of amps match my speakers?
If i gt this Polk 4ch amp, would I be able to plug all 4 speakers into this amp? Do I still need to use the cross-overs that came with the speakers?
Im not too good with the tech stuff but I love sound with a passion and I thrive for accuracy.
I was very pleased with the results i got when i upgraded my speakers to Polk and i think i want to stick with them all the way.
I would like to get a 12inch sub installed in the future.
Thanks for reading my post and I would really appreciate some good advice!
- Mike
Post edited by kayo_michael on
  • knieght rieduz
    knieght rieduz Posts: 7
    the sound becomes distorted at highvolumes because basically your speakers are being underpowered. you are correct in looking for an amp, and it will be a big difference as far as power/sound goes.
    the c400.4 is said to be a good match becuase it gives out around 75 watts RMS x 4 at 4 ohms. so this means each speaker will be recieving right around its power handling capabilities and will make them sound much better than being powered by your hu alone. hope this helps
  • MacLeod
    MacLeod Posts: 14,358
    Agreed.
    At 70%, your head unit is putting out pure distortion and clipping badly. The C400.4 would be a perfect match for those speakers. You would still have to use the supplied crossover with your 5x7s.
    I highly recommend you get the amp. You wont believe the difference in SQ. It will be the difference between driving a '71 Pinto and a '05 BMW 7 series.
