Paradighm PW-2200 .v2 compare to the SVS PB12-ISD?
How does the Paradighm PW-2200 .v2 compare to the SVS PB12-ISD?
Post edited by rkn2903 on
  • rkn2903
    rkn2903 Posts: 13
    edited March 2005
    Have anyone compared the two, I know the Paradigm pw2200 .v2hits very low and deep and very clear not sure about the SVS.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited March 2005
    Paradigm kicks A$$, sorry a Paradigm fan here. :D
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • rkn2903
    rkn2903 Posts: 13
    edited March 2005
    I compared to my brothers SVS12, and seems to be more cleaner and deeper, but his sounded pretty good for the money, so I guess I got a pretty good deal on the 7 month old Paradigm for $520 total. Thanks
  • disneyjoe7
    edited March 2005
    I must say SVS seems to be the value leader.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • goingganzo
    goingganzo Posts: 2,793
    edited March 2005
    svs great bang for buck. the olny way to do better is used or diy. i perfer diy.
    VR3 Posts: 29,696
    edited March 2005
    Man I'm sorry...
    but it will be hard to be 'deeper' than a SVS, much less you know it just by listening with your own ears...
    As for how clean one can be, it all depends on placement and calibration...
    I have my SVS set up now where I can barely tell it is on, and I've also had it to where the neighbors knew it was on, and its at the same volume...
    All about the setup...
    Also note, some SVS box subs dont use bracing, so the cabinet may resonate and present a 'boom', where the cylinders don't require any bracing and barely resonate
  • rkn2903
    rkn2903 Posts: 13
    edited March 2005
    Depends on what SVS your comparing the paradigm pw 2200 .v2 to.
  • goingganzo
    edited March 2005
    i dident know that. my sub is braced to the max dubble thick mdfb 2x6 fraim with a 2x4 sub fraim 2x4 between every sub. it is atached to the floor with masanery screws and construction aheasave.
  • rkn2903
    rkn2903 Posts: 13
    edited March 2005
    Paradigm sub cabinets or braced to prevent resonating.
