DVD Recorder
glemay
glemay Posts: 574
edited February 2005 in Electronics
We just got a DVD Recorder, it's a Pioneer DVR-720H-s. Been playing around with it but can't seem to get it to cooperate.
When I put a music CD or DVD in should I be able to copy it to the HDD without having to play it right through.
Who else has a DVD recorder? What are your experiences?
Gerald
Main System:
Denon AVR-2805, Polk Audio RTi70's, Polk Audio CSi40, Polk Audio FXi50, Paradigm PW-2200 v.2, Toshiba 42XV545U HDTV
Second System:
Denon AVR-1705, Polk Audio R40, Polk Audio CS245i, Polk Audio R15, Paradigm PS-1200a
Post edited by glemay on
    F1nut Posts: 51,770
    To the best of my knowledge you can not record a pre-recorded CD or DVD to the harddrive. It's copyright protection.
  • glemay
    glemay Posts: 574
    What about a burnt CD? Should that be able to work?
    Main System:
    Second System:
    F1nut Posts: 51,770
    I don't think you can record any format to the hard drive except from broadcast signals. However, all it says in the ad's is, "Internal dubbing of copy-protected DVD's is not possible." Read your owners manual, I'm sure it tells you in there.
  • peekobi
    peekobi Posts: 58
    I'm not sure what I want but in order to record some TV shows, is there a product that records on DVD's instead of a VCR and tape?
    I was looking at a Toshiba D-R2 and a Panosonic DMRE55S at hh gregg. They run around $250-300. Is this all I need just to watch a few shows that I may miss when I'm out? Thanks for the help!
    Reciever Onkyo TX-SR708
    Center - polkaudio CS245I
    Mains -- polkaudio RT600I's
    Sides -- polkaudio RT35's
    Rears -- polkaudio RT25I's
    Sub ---- polkaudio PSW-350
    TV: Panasonic TC-P50GT30 HDTV
    Blu-Ray Player Panasonic DMP-BDT215
    Common sense ain't that common!:loneranger:
    F1nut Posts: 51,770
    Yes, you want a DVD player/recorder. This link may help find one suited to you.
    http://hometheater.about.com/cs/toppicks/tp/aatpdvdrecorder.htm
