1 Large Amp vs. 2 Small Amp Bi-wired.
disneyjoe7
I'm sure this has been discussed before, but let's recap ok.
Is it better to Bi-amp with say 200 watt amps by 4 for 2 channel music or 400 watt amp by 2? We will be talking the same amp family not 4 channel of X to 2 channel Y.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR
Post edited by disneyjoe7 on
i find more power going to the whole speaker works better in my experience, but your going to get varying answers on this question. if you have the ability to try both, do it. if not, i would go with the fewer high power amps then with more less power amps.Living Room 2 Channel -
Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
Upstairs 2 Channel Rig -
Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites -
ohskigod,
I see that you bridge your amps is that better then 1 large amp?
Ok a new can of worms
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
WMC Win7 32bit HD DVR -
You need to keep the amp powering the tweeter from producing a full 20-20 signal. PE sells passive crossover connectors for this... this lets the amp concentrate on just the high end signal and free up power to bring the most out of the top end....
I prefer biamping- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Originally posted by disneyjoe7
ohskigod,
better? i dont know, some would probably tell you to get one large amp. it's probably more subjective than the biamp/more power debate
i bridge my amps that way simply to effectivly use what i have. i have collected the amps over time (constant upgradeitus) and this is just the latest form of it. might someday get one large amp, either a rotel or the outlaw to match my new pre pro. but with the theater sounding as good as it does lately, i am in no rush whatsoever to upgrade the amplification.Living Room 2 Channel -
Thanks I have to agree it's best to use what you have.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Steve,
Agree that in your opening example I'd opt for the 2 x 400 option... and bi-wire for good measure...
(BTW... in your 4 x 200 option you are bi-amping, not bi-wiring.)
By most estimates 85% or so of the power demands in reproducing music are in the lower frequencies, so why apply only 200 wpc to that area when you can use 0.85 x 400 = 340 wpc???
As for bridged vs. mono-blocks? I'd give a slight edge to mono-blocks... Not really based on anything other than bridged mode is secondary application.
Haven't visited Sid's thought on passive filters between Pre-amps and amps in a bi-amp mode in a long while. I do remember an old discussion about when there are already cross-overs in play in your speakers, it's problematic (but if you picked one for the HF duty that crossed over significantly lower than your built in.. hummmm...).
More later,
Tour...
Vox Copuli
Tour2ma,
BTW what is that "Tour to Massachusetts"?
I on the fence right now doing either A, B, or C?
A.) buy a Parasound HCA-2200 for $600 now adding another later for Bridging or Bi-Amping. I have to see what sounds better.
B.) wait save a little more for a HCA-3500 for $1500? In this case just Bi-Wire the speakers.
C.) Do nothing. Wait that may just kill me.
Sorry for any confusing before Bi-Wiring I meant Bi-Amping.
Powering the mighty great sounding RTi150's IMHO, take that for what it's worth.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Took me a minute, but I got it... MA = Mass...
But since it's lower case, Tour 2 milliampere is more likely....
A.) ain't bad, especially if...
D.) use your current amp for the highs and the 2200 for the lows...More later,
Tour...
Vox Copuli
Come on dud, I sure you run on more then milliamps
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
A.) ain't bad if D.) is an option...More later,
Tour...
Vox Copuli
400 wpc will give 3 db more headroom for any single frequency to use than 200 wpc biamping since only 200 watts exists for the single frequency.
When that huge bass note or explosion hits, 400 watts can go to it instead of 200, thus for sheer overhead the larger amp gives more room on any single given frequency.
When a chord that extends from low to high such as a symphony would give you, the 2-200 watt amps will deliver the same amount of output power since the frequencies are spread out and then the 2 amps may be able to deliver the sound cleaner.
Highs with their own amps need not be affected by the amp trying to overcome bass damping needs on the same amp.
Does that make any sense?
DGHT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Option A.)
Wouldn't work alone right now? I use a HK PA2000 100x2 bridged 4x35watt wonder. With my Onkyo 898 110wX7 (nice?) AVR for the tweeters. So if this added up to 210w total then why wouldn't 250w improve the sound.
I thinking 250w x 2 right now then adding another for 250w x 2 to Bridge them to 750w x 1 each. for the sum of $1200 vs the 3500 for 350w x 2 for $1500.
It sounds to me I'm not on the right track.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
DG
Clear as MUD, no just kidding
Beautiful statement.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
