Help w/ new reciever or amp & pre
timothyj
Hey guys, I'm bummin' right now. My NAD T752 is out of warranty and the surround R channel is out - this unit has had a history of amp problems and I refuse to spend hundreds to get it fixed as I'm confident problems will continue to arise. The pre-amp out won't even work for the surround R channel or the sub channel.
So. . . what should/can I buy - I've only got about $600 to spend and need to drive 3 Lsi7's and rt25i's for surround.
I'm up for any suggestions - maybe just start with a good surround pre-amp and do stereo until I can afford more amps. I dunno - HELP!
Tim
LSI7 x 3 (fronts)
rt25i x 2 (surrounds)
SVS PB-10 NSD
Harmon Kardon 235 pre/pro
NAD amps
Xbox 360
Pioneer DV-578A (DVD, SACD, DVD-A)
LSI7 x 3 (fronts)
SVS PB-10 NSD
NAD amps
Xbox 360
Post edited by timothyj on
tj,
First, contact NAD... If your repair history has been unually bad, they might work with you... Couldn't hurt to ask, but assuming they tell you to take a hike...
Tight budget for powering up that line up... Certainbly there are some AVR's you could make do with, but I think, as you suggest, a step-wise approach would be the way to go...
A few questions first...
You've been running a 7.1?
It's the right side surround that's out, not the rear? If so, can you just run 5.1 for a while?
Can you run your sub on speaker level connections for a while?More later,
Tour...
Vox Copuli
I'm just running 5.1, 3 lsi7's and one pair of 25i's.
So now I've got a mutated 4.0 with no right channel and no sub. The NAD T752 has pre-outs for 7.1, but only 5 amps built-in.
I'm in an apartment, so I'm just doing without the sub for now - but yes, I could hook it up to the front pre-outs.Tim
LSI7 x 3 (fronts)
SVS PB-10 NSD
NAD amps
Xbox 360
Pioneer DV-578A (DVD, SACD, DVD-A) -
OK...
Well you can run a 4.1... If you can get the rear "1" behind you, that'll work. Most rear surround is mono anyway...
There's another thread about AVR choices in the $300 to $600 range you may want to look into...
On the sub... if you use a main Pre-Out, does that kill the signal to the NAD's internal amp for that channel? It does in some AVR's...
And do call NAD come Monday...More later,
Tour...
Vox Copuli
