Components or normal?
fatfree
have an Acura Legend with stock 8 speakers.
The fronts have tweeters located right next to the 6.75" speaker, they are located on the lower door panel.
This is how it looks - the "o" is the tweeter:
o(6.75)
My stock rears are 6 X 9s and they have tweeters between them, all located on the rear deck.
(6x9)----o----o----(6x9)
Mkay, my question is, should I get component speakers and put the tweets in stock location, or should I just get regular speakers with built in tweeters? If I get component, the only place I will put tweeters are in stock location.
Which type would sound better, or would they sound the same since the tweets are close to the speakers?
- I'm not going to have subs
- I probably will buy an amp
Please let me know... I don't want to waste my money on components if they are going to sound the same since I won't relocate the tweeters.
BTW, I'm looking towards DB690 and DB675. I was thinking about MMC690 but I read the reviews and most reviewers complained about the lack of bass. While the DB690 had better reviews.
Thanks!
o(6.75)
Thanks!
Post edited by fatfree on
for the front, id get components, for the back, id get coaxials(the speakers with the tweeters on them)
or better yet, you could buy some little 6" subs and put in the back. as a whole it would sound better.
There is currently a Group Buy going on at another forum for Resonant Engineering (www.reaudio.com) where you can get your hands on a sub for $37, and this will be much better than anything over at Circuit City or Bose. The link to the forum is http://forums.caraudio.com/vb/showthread.php?t=84160, or you can call this number: Resonant Engineering (702) 896-4823 and it running until Feb 18th with product going out on the 28th. The cool thing is you dont even need to be a part of that forum, just call the number and your done.
id grab a set of the RE XXX6.5s and build a small ported box for em if you can, if not, then thats fine.
youll have to build something very similar to this so theyll fit:
http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=24444
power everything with this amp:
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=13125
check ebay or knukonceptz.com for wiring and youre set
-CodyMusic is like candy, you have to get rid of the rappers to enjoy it
