Got my 1500a Parasound today
minime
minime Posts: 42
edited February 2005 in Speakers
should i turn the THX levels up all the way ,I have a Denon 3802 and wanted to make sure it could handle it,I also went with the biwire seemed to be the right thing ta do,cant wait to get it up and running. and any other pointers or info is nice:)
Post edited by minime on
  • Kevinvb11
    Kevinvb11 Posts: 105
    ,I also went with the biwire seemed to be the right thing ta do,cant wait to get it up and running. and any other pointers or info is nice:) [/B]
    Just get it up and running for now.
  • dorokusai
    dorokusai Posts: 25,577
    The adjustable gain, which is what your talking about, should be at the maximum for it to be at THX reference level.
    Excellent amplifier, have fun.
  • minime
    minime Posts: 42
    Ive got it hooked up on stereo with the left and right power cables pluged in here to my Denon front left and right channels, im not getting much sound here need help first amp? Do i go to direct mode
  • Mike Reeter
    Mike Reeter Posts: 4,315
    I can only "assume" that you have RCA cables running from the L/R outputs on the Denon to the inputs on the back of your amp...
    Speaker wire running from binding posts on the back of the amp to the speakers? Right?
    Any other speakers,C,L/R and back Surrounds are still being driven by the Denon...
    I can't imagine not getting an improved sound out of your L/R Mains,unless,somethings just not "right"
    You might have to recalibrate the system,anytime you make changes,you should do this...
  • Tour2ma
    Tour2ma Posts: 10,177
    Are you interconnecting the Parasound to the Denon's "Pre-outs" (correct) or its "Amp In" RCA jacks?
    More later,
    Tour...
    Vox Copuli
  • lomic
    lomic Posts: 407
    It's probably too late, but as a future precaution I've heard many times that, especially when dealing with an amp make sure you turn it off *and* unplug it before connecting or disconnecting anything to it.
    Dodd Audio ELP [ Tubes ] // Harman Kardon AVR330 // Parasound HCA-1203A // Denon DVD-2900
    Polk Audio LSi9, LSiC, LSi 7 // HSU STF-2 // Signal Cable Interconnects (SG BW/A2/MP)
  • minime
    minime Posts: 42
    I guess it had to reset once everything is hooked up.I didn;t have a lot of time to mess with it last night but when i got home today i turned on both sets and it was working.Thanks again.One more question do you have to turn the amp on and off everytime you use it.I was thinking it would turn itself off and on.
  • cfrizz
    cfrizz Posts: 13,415
    Hi Minime. We have the exact same equipment. You will have to turn on the amp manually, since the 3802 doesn't come with a trigger.
    I have gotten into the habit of just leaving mine on all the time. otherwise I forget to turn it on and then wonder why it doesn't sound right!:o
    You will love all the extra power you now have. Enjoy.
    Cathy
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    If the AVR receiver has a switched outlet, then add a 12vdc wall transformer wired to the 12vdc trigger. So when you turn receiver on then it will turn on amp also. That's what I do :D
    BTW I do it this way (vs. Auto ON by sound) because if you're are using the amp in HT also then at times the amp can shut off due to extended quiet times on the surround channels.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
