surround speaker
bolelet1
Hey guys, please help me on this. I am I just hooked up my system and noticed that the right surround speaker doesn't sound right. it is somewhat distorted. I ckd the speaker connections to make sure the wires are connected to the right poles. But still the speaker sounds the same. the left surround speaker is OK. At first I thought the rm201 has a factory defect cuz i just bought it like a couple of weeks ago. I tried connecting an old radioshack surround speaker, but it too was distorted. Could it be that i bought a defective receiver. Any help/advise would be greatly appreciated. Thanks.
My system:
Yamaha RXV1400
Yamaha DVD S-550
Polk Audio Speaker RM20
My system:
Yamaha RXV1400
Yamaha DVD S-550
Does it sound bad in DD/DTS 5.1 discrete as well, or is this problem only in Prologic? Maybe try something more radical and hook your mains up to the rear outputs on your AVR. If it's still funky, then it's likely your AVR.
Is this your first AVR? I had a problem once with my amp where one of the channels got messed up after the repair guy came and didn't properly ground the satellite dish - almost had a heart attack until I retraced what he did and fixed it. Anyway, if you haven't had a reciever before, make sure everything in your system has proper grounding.Dodd Audio ELP [ Tubes ] // Harman Kardon AVR330 // Parasound HCA-1203A // Denon DVD-2900
Polk Audio LSi9, LSiC, LSi 7 // HSU STF-2 // Signal Cable Interconnects (SG BW/A2/MP) -
Yes, this is my very first receiver and i forgot to mention in my prior thread that this receiver is 7.1. At first when the surround speakers were not hooked up yet and only the front, center and back surround were hooked up, the system was nice. then i decided to add the surround speakers and then the problem. I program the receiver to auto as recommended by Yamaha. Now I am really at a lost cuz I bought this receiver when I was in Hongkong. If this is a grounding problem, do I need to ground the receiver and how do I do it? Could it be with the wire, although i am using monster cable as recommended by Frys. I am really new to this so please help me. thanks.
Have you checked to see if the receiver is set up for U.S. power? 115v 60hz. -
yes i did
Have you ruled out the speaker wire as the culprit?HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
not really. do you think i should try switching the cable wires to determine this?
When you say you programmed the reciever to "auto" do you mean you used the yamaha thing where you hook up the mic and it adjusts speaker levels? If so, override that and set all the gains to zero and see if the distortion is still there. There's nothing to keep it from cranking the gain all the way up and sometimes it'll unnecessarily do that and you'll get a distorted channel.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
I did programmed it that way and even during the testing process, i already noticed the distortion. I will try setting the sound level manually and see the effect. Thanks!
