Please Explain
janmike
janmike Posts: 6,146
edited February 2005 in Electronics
I have had some very good advice lately in regards to adding an 2 Ch amp to my system. I currently have a Yamaha RX-V1500 that puts out 120w per channel. I am currently using 5 speakers (2 Front, 2 Surround, 1 Centre)I. If I add an amp (120w/ch), why can I expect better sound out of my front speakers for 2 CH stereo. Is it actually taking some of the load off the Yamaha? Thanks Folks.
Michael ;)
NORTH of 60°
Post edited by janmike on
  • hoosier21
    hoosier21 Posts: 4,415
    do a simple search here on the forum, many posts about this.
    But yes it will sound better, it will take some of the load off the receiver.
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • dcarlson
    dcarlson Posts: 1,740
    The idea is that the amp you use will be of greater quality than the one in the receiver. Thus a better sound.
    SDA-2a, Anthem Pre-2L, Anthem Amp 1, MF A324 DAC, Rotel RCD1070
    Senn HD650 Cardas, Mapletree Audio Ear+ HD2, Kimber KS1030, Bel Canto DAC2, M-Audio Transit, Laptop.
  • janmike
    So if my Yamaha is delivering 120w to the front, should I look for more than 120w/ch?
    Michael ;)
    NORTH of 60°
  • izafar
    izafar Posts: 819
    Not all 120 Watts are created equal. You will always get better SQ when you are going with a seprate Amp rather then a reciever. Any stereo amp by NAD, ADCOM, Carver and Rotel etc will sound better then your receiver even if it has lower # of ratted watts on specs.
    let us know what speakers you are using and we can recommed an Amp accordingly.
    -izafar
    Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano
  • tryrrthg
    tryrrthg Posts: 1,896
    Not necessarily. Chances are your Yamaha is not delivering a TRUE 120 watts. Just look for a higher quality amplifier. Most amps (of any power) from the likes of Rotel, NAD, Adcom, etc would be an improvement over the yamaha amplifier section.
  • steveinaz
    steveinaz Posts: 19,545
    It's not more power that you need, but better components. A seperate amp (provided its a good one) will give you better fidelity overall. Most people can get by with as little as 65 watts/rms in most cases.
  • janmike
    My Speakers are as follows:
    RTi100
    RTi38
    CSi5
    Rotel & Parasound have bee n suggested.
    Michael ;)
    NORTH of 60°
  • Tour2ma
    Tour2ma Posts: 10,177
    jm,
    Both produce well regarded amp lines.
    Both utilize high current designs (the reason folks can as steveinaz put it, "can get by with as little as 65 watts/rms").
    Either will wake up your mains to a greater extent than your Yammie.
    More later,
    Tour...
    Vox Copuli
  • LuSh
    LuSh Posts: 887
    What's your source? Focus on that, its the most critical link for two channel reproduction.
