Question for any Web guys out there...
AsSiMiLaTeD
Let's say I have a collevtion of 1000 music files...
Does anyone know of a utility that index those files and create a set of HTML pages with links to those files? My wife is always listening to my music and I'd like to create an HTML interface to make things easy.
I know I can do this with any HTML program, but would like to avoid the hassle...
I know that Winamp can build an HTML playlist, but I'm not sure that it links to the files... it might just make a list.Ludicrous gibs!
Polkmaniac, is there a specific reason you wanna go HTML route. I think you can use any good freeware jukebox program that can provide you a very good access to your music. I like iTunes for this purpose.
If you wanna go HTML route and hava a webserver running on you machine then simply publish the music root folder on the webserver and turn the directory browsing on. This will provide pretty easy interface to all music files in the browser.-izafar
Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano -
I wanna go HTML so we can also access files remotely.
I am currently running Apache with directory browsing enabled, was just wondering if there is another way... -
I think this might serve your purpose: http://www.flippet.org/wawi/about.shtml-izafar
