Subwoofer recommendation
BakedWafer
See my sig. Can anyone recommend a decent subwoofer?
Regards
Regards
Post edited by BakedWafer on
If DIY is a viable option I'd say build an Adire Tempest. Performance to dollar ratio is outstanding and they're fairly easy to build if you've got shop access.
Outlaw 950
GFA-555
GFA-545
GFA-2535
RTi8s
CSi5
FXi3s
214L Vented Tempest
250w BASH amp
Toshiba HDA1
Toshiba 44" DLP
NAD 533 Turntable
Tripplite HT3100
Xbox 360 -
What have you thought about so far.
If you haven't already, check out www.svsubwoofers.com to see if any of thier many choices suit your needs.Tschüss
Zach -
Looked and both Velodyne and the B+W Subs so far, both seem overpriced.
Maybe it's just me. -
check out stryke
