Bi-wire A and B?
Adrien Wagner
Adrien Wagner Posts: 4
I just got some RTi8 towers and I have trouble finding information on Bi-wiring, I have a Sony DE595 Receiver and it has speaker "A" and speaker "B" slots and an option to run them both, so my curiousity got me and I Bi-wired using both slots and it sounds great, but I have nothing to compare it to. Is that how you're supposed to Bi-wire, am I dumb? is there another way? Should I splurge for another amplifiier so I can Bi-amp?
  • dorokusai
    dorokusai Posts: 25,661
    edited January 2005
    I'm sorry man, and I'm a Sony fan, but bi-wiring should be the least of your worries.
    Buy some Sony ES, or look into another brand of AVR or separate amplification.
  • Frank Z
    Frank Z Posts: 5,860
    edited January 2005
    The connection your descibing is Bi-amp, not by wire. You do have something to compare it to, simply disconnect the speaker wires from the "B' terminals and from the speakers. Re-install the the jumpers on your speakers and your back to the standard connection. Listen to it foe a while and see how it sounds.
    BTW, There are a bunch of threads here regarding bi-amp/biwire.
  • gregit
    gregit Posts: 284
    edited January 2005
    hmmmm...how can it be bi-amp unless there are 2 amps running separate A & B outputs? Isn't the A B selector only a switch? Seems like it would be bi-wire in this case.
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited January 2005
    It's ghetto bi-amping at it's finest.
  • Pinktulip7
    Pinktulip7 Posts: 249
    edited January 2005
    Dude do your homework first....What do you want realy?
    TV :>Panasonic TC-P55VT50
    RECEIVER :> HARMAN KARDON AVR 7300
    FRONT :> L & R :> POLK RTI A9 500 W
    AMP :1> PARASOUND HALO A21 250 W
    AMP :2> EMOTIVA UPA-1 200 W
    CENTER :> POLK LSiM 706c 250 W
    SURROUND SIDE :> POLK RTi A3 150 W
    SURROUND REAR :>POLK FXI A6 150 W
    DVD PLAYER(HD) :>TOSHIBA HD X-A2
    DVD PLAYER(BLU-RAY) :>Panasonic DMP-UB900
    POWER CONDITIONER :> PANAMAX M5400-EX
    SUBWOOFER :A> SVS SB16-Ultra 1500 W Front
    SUBWOOFER :B> SVS SB16-Ultra 1500 W Rear
  • Adrien Wagner
    edited January 2005
    see, what I did was hook the high input on tower 1 & 2 to slot "A" and the low input on tower 1 & 2 to slot "B"............ Like I said, it sounds good this way but could I harm my stuff? Is there another hook-up that sounds better? I have muscular dystrophy so. the least amount of messing around and expirementing is what I'm looking for.
  • dorokusai
    edited January 2005
    When the AVR shuts down with a message like "Protection", is when you are on your way to harming the unit. If that hasn't shown up yet, business as usual.
  • unc2701
    unc2701 Posts: 3,587
    edited February 2005
    You're bi-wiring- the A and B buttons just close relays to hook those speaker jacks to the left and right amps. So you'd get basically the same thing hooking both wires to the A output... but it's probably easier to hook them up to the seperate jacks. Don't worry about harming your amp- basically all you've done is move where the High & low are connected from those jumpers at the back of the speaker to a connection inside the amp.
    However, like the other guy said, you've got a lot more to worry about- like why are you using Sony?
    Backburner:Krell KAV-300i
  • dorokusai
    I am "other guy".
    Here we go, with the general comments about Sony and how they suck.
    I would love to hear you elaborate about your Sony experience(s). Please elaborate extensively.
  • Adrien Wagner
    Originally posted by dorokusai
    I am "other guy".
    I'm probably not the person to talk about Sony because they're basically all I've used and know (they're the right price for me) but my Dad has a pioneer receiver thats about 3 yrs old and it uses the same technology as my 1 yr sony. My brother has a sony HTB and he loves it, it is newer more expensive sony and it is the best I've ever seen. with sony I would conclude That the higher end more expensive stuff will perform wonderfully however I have heard and read that Denon outperforms in DVD,AVR but the prices get up there and anything over $1000 is out of my league.
  • dorokusai
    Adrien - I was directing that at UNC, not you, I apologize for not making that a little clearer.
  • unc2701
    I should clarify- Sony TV's- great, awesome, love them. Sony computers- way overpriced, but at least they look good. Sony audio- sucks. Everything bad that has ever been said about solid state amplifers is true for Sony. They're harsh, grainy, noisy, distort well below their rated specs, can't drive low impedence loads... Up until the govt. made them change, they would advertise their peak wattage instead of the RMS, so a 70 watt Onkyo could blow away a 110 watt Sony. Mass market at its worst.
    Now, I probably haven't given their top end a fair shot- I auditioned their top of the line receiver last time I was in the market and thought it sound like crap, but it was on the store's speakers and they weren't playing my kind of music... so maybe with a decent setup, they'd be ok, but for the cost, you might as well go to seperates and pick up an old adcom, bryston, NAD, rotel, etc for a power amp.
    In the under $1000 league for a receiver, go with yamaha, onkyo, Dennon. I've got nothing against HK and the ones I've heard sounded fine, but I've also heard plenty of complaints about them breaking.
  • Tour2ma
    Tour2ma Posts: 10,177
    Originally posted by Adrien Wagner
    I Bi-wired using both slots and it sounds great...
    That's all that matters...
    Welcome to the forum...
    More later,
    Tour...
    Vox Copuli
  • dorokusai
    Ah, the atypical generalizations, an expected response.
  • Tour2ma
    That's it? ;)
    More later,
    Tour...
    Vox Copuli
  • unc2701
    uhhh, how about the fact that their top of the line receiver has an advertised THD of 0.15%? I mean, that's not just bad, that's terrible... but if you like, 'em, knock yourself out
  • Tour2ma
    Now you're going to piss off the Carver fans, too...
    0.15% THD at rated output is negligible.
    More later,
    Tour...
    Vox Copuli
  • unc2701
    hehe... yeah, I don't like those either... but I'm using brystons, which you can crank about 25% past their rated power and still not see 0.08%. I agree that there more to it than specs, but when 1) they sound bad to me and 2)they've got bad specs, you gotta go with something else. For me, just about anything but sony will do.:)
    F1nut Posts: 52,406
    I dragged a pair of 7B-ST's home, found the Bryston sound to be cold even run through a CJ 17LS.
  • Tour2ma
    Cool... how about a nice Panasonic??? ;)
    For most of us your #1, how it sounds is enough...
    Look, no one is saying that Sony basic line is great stuff. It isn't, but what it is is decent entry level gear on the whole with some pieces that are better than others. General bashing is just not called for.... and no, doro's opening remark was not bashing, but rather a comment that bi-wiring entry level gear should not be a priority.
    Sony ES is a completely different class of gear than their base line. Great? Again depends on the piece in the line. Some are certainly near great...
    As for Bryston spec's, they are simply ultraconservative. And in the class of gear they compete, they can afford to take that approach...
    How does Bryston sound? Like F1, I found Bryston left something to be desired. He said, "cold". Similarly in the audition I had years ago, I found them to be kinda "analytical"... TBH, couldn't even start to explain what brought me to that, but that's the word that has stuck with me...
    Not meaning this as backlash...
    EDIT: I have audio biases as well... I either refrain from any comment on Pioneer gear, any level of it, or at the very least state that I have a bias against it...
    More later,
    Tour...
    Vox Copuli
  • unc2701
    panasonic? how 'bout a nice technics? :eek: So, yeah, I take your point. I'll back off my "sony sucks" and offer that I don't like the way sony overinflates their wattage by having rediculously high distortion compared to other receivers and they shouldn't have to do that on their high end or their low end. oh, and personally I don't like the sony sound.
    As for the brystons, yep, they're cold. But if there was a noisy slider on the mixing board in the studio where the CD was recorded, I want to hear it. Some people want to cover it up with nice warm amp, but not me. Granted they will drive you nuts trying to find the bad cable in your system that's making that noise when it's just something on the recording.
    Wow... this has totally wandered off topic- my bad.
  • Tour2ma
    I think Adrien got the info needed... and a bunch of entertainment to boot.
    Funny you made the comment you made on the Bryston. Spoke to one owner who said it was a totally revealing amp, that it would expose any weakness, anywhere in your rig... Maybe I was talking to you.... ;)
    More later,
    Tour...
    Vox Copuli
  • unc2701
    nah, I'm new around here... but I gotta agree with whoever you were talking to- there's a reason why just about every studio uses them... if it's there, you'll hear it.
    F1nut Posts: 52,406
    nah there's a reason why just about every studio uses them...
    While that's not true it may explain why we have such crappy recordings from many studio's. Everybody knows that the best studio's use tube gear.
  • unc2701
    ok, two clarifications:
    1)"every studio" is an exaggeration, but they're very popular... Abby Road, Capitol, atlantic, HBO, and lucasfilm use them just to name a few...
    2)They use them to power studio monitors
    Now I don't disagree, good studios will have mic preamps, guitar amps, a variety of effects, etc that are tube rather than SS... and they'll have some tube power amps on hand to power their monitors if someone wants 'em. But most sound engineers are going to want SS for monitoring, simply because tube amps are too forgiving... They'll play over a crappy recording and sound great and that's exactly what you don't want for monitoring. You'll tend to see tube for most stuff before the tape, SS for stuff after the tape.
