6x9 to 6.5 Conversion
Systems
Systems Posts: 14,873
edited January 2005 in Car Audio & Electronics
I got the MMC6500's and everyplace I read and asked said that they would fit my 2004 4runner As it turns out the factory set up is 6x9. I want to stick with the components. Do these conversion kits work I've heard mixed reviews. Any other ideas that aren't overly complicated (I'm running out of money for complicated (-: )
I did get the Orion 4004 and the Alpine head unit installed and I can't believe how much better it sounds just running the factory speakers!!!! I can't wait to hear the MMC6500's! Thanks again for the advice.
Testing
Testing
Testing
  • MacLeod
    MacLeod Posts: 14,358
    edited January 2005
    Do what I did. I went down to Lowes and bought a sheet of 1/4" birch plywood and cut out baffle plates. A whole lot cheper than a $25 adapter kit, not to mention wood is a 100 times better mounting surface than the plastic adapters.
    Go to "The Install" thread. I have some pics of the baffles I made to stick my 6.75" MM6's in 6x9 wholes.
  • Systems
    edited January 2005
    Thanks. I just saw your pic's nice!
    Testing
    Testing
    Testing
  • swerve
    swerve Posts: 1,862
    edited January 2005
    6x9 wholes? Like the whole 6x9 or the whole MM6... I'm confused. How exactly to you cut a whole.. if you cut something it isn't whole anymore.. please elaborate more macleod!!!
    :D
    -adam
    cats.vans.bag...
  • spwuinmk67
    spwuinmk67 Posts: 797
    edited January 2005
    Looks like we found another for someone's sig...:p
    1993 Ford Ranger super cab:
    Pioneer Premier DEH-P880PRS
    MB Quart QSD216
    in need of amps and subs
    Home:
    52" Sharp Aquos
    PolkAudio Monitor 10's
    Harmon Kardon HK3375
    Xbox 360
    PolkAudio XM tuner
    Owner and co-designer of www.basicholdem.com
  • MacLeod
    edited January 2005
    How bout ya kiss my WHOLE ****?! ;)
  • exalted512
    exalted512 Posts: 10,735
    edited January 2005
    you can kiss my **** whole...
    -Cody
