new slp meter
tecmo04
i just bought the radioshack analog slp meter (33-4050).
how do i set it up so i can tell how low my bass is going?
Post edited by tecmo04 on
An SPL meter is used to measure decibels, not frequency. What you want is test tones to download and burn to a cd, then use them in conjuction with your SPL meter to tell you how loud your bass is specific frequencies. Check out my thread for test tone download links, as well as the correction factors needed.
Outlaw 950
GFA-555
GFA-545
GFA-2535
RTi8s
CSi5
FXi3s
214L Vented Tempest
250w BASH amp
Toshiba HDA1
Toshiba 44" DLP
NAD 533 Turntable
Tripplite HT3100
Xbox 360 -
Well that's what most people around here use them for. Are you just wanting to find out how low your sub will go?
Outlaw 950
GFA-555
GFA-545
GFA-2535
RTi8s
CSi5
FXi3s
214L Vented Tempest
250w BASH amp
Toshiba HDA1
Toshiba 44" DLP
NAD 533 Turntable
Tripplite HT3100
Xbox 360 -
Originally posted by tecmo04
how do i set it up so i can tell how low my bass is going? -
i am very curious how low my sub will go yes. does the digital one give hi and low frequensies?
Download these test tones, they are a one frequency tone ten seconds long. You could start at 16hz and go up in increments of two to save a lot of downloading. Burn them to a cd, then play them on your stereo with your SPL meter in hand and it will tell you how loud your sub is at each frequency. Your figures will need to be corrected as mentioned in the thread I linked. Then you could make a graph and look for any dips or spikes in the frequency response and try to flatten them out.
Outlaw 950
GFA-555
GFA-545
GFA-2535
RTi8s
CSi5
FXi3s
214L Vented Tempest
250w BASH amp
Toshiba HDA1
Toshiba 44" DLP
NAD 533 Turntable
Tripplite HT3100
Xbox 360
