Something I just notice about my CSi5 kinda weird
Dannieboiz
Dannieboiz Posts: 242
edited January 2005 in Speakers
I was just messing around with my CSi5 yesterday and found that the 2 6.5" driver aren't putting out the same sound/power. One sounded more like a filler the other one seems to play at full range is this right? I had 2 pairs of CSi5 in possesion and tested the other one too and it did the same...
Sammy UN55C6400
Onkyo TX-SR875
Def Tech: Mythos One, Three, Six
Velodyne DPS-12
MartinLogan Dynamo 10
Post edited by Dannieboiz on
  • okiepolkie
    okiepolkie Posts: 2,258
    edited January 2005
    They are supposed to do that, but I can't remember righ now why?
    Tschüss
    Zach
  • Dannieboiz
    edited January 2005
    lolz you're on every post of mine man. Are you stalking me? lolz or should I say do you ever leave this place?
    Sammy UN55C6400
    Onkyo TX-SR875
    Velodyne DPS-12
  • Snoopdog
    Snoopdog Posts: 16
    edited January 2005
    Cascade Tapered Driver Array: Some center channel speakers, due to their horizontal design, have a difficult time evenly distributing the sound throughout the listening area. To combat this problem, the speaker features a "cascade tapered array," meaning one woofer plays only the bass frequencies, while the other handles both bass and midrange. This setup results in broad, even sound dispersion, and a better overall surround sound experience.
    Jeff (Snoopdog)
    It was my nickname before the rapper was born.
  • okiepolkie
    edited January 2005
    Stalking is such a self incriminating word.
    And wes, I have been spending quite a bit of time on the forum. No particlar reason, just enjoy it here I guess.
    Zach
    Tschüss
    Zach
  • Dannieboiz
    edited January 2005
    yeah man I like it here too,
    So I supposed that's a good thing? I think it's a waste of the other driver, but what do I know.
    My HK doesn't allow me to set my center channel as "large" when I'm using optical cables or certain surround mode. The only one I see possible is 3 channel stereo. I just missed a deal for a Denon AVR3300 for only 300 bucks I was so pissed. I think the Denon would be a better match for my speakers. My cousin has the 2800 with some paradigms and they sound pretty good for just bookshelfs and sub.
    Sammy UN55C6400
    Onkyo TX-SR875
    Velodyne DPS-12
  • Willow
    Willow Posts: 11,233
    edited January 2005
    funny I don't see why an optical cable would make the receiver not allow to do that.
  • Dannieboiz
    edited January 2005
    THere are certain surround modes that I can't get into. Also which connection is better? I currently have my DVD player hooked through a toslink optical cable. I have some Component video/audio cables left and they are low loss 75ohms cable that are pretty high quality I will only need 1 of those cable for a coax hook up. Which would be better? Coax or stay with my toslink?
    Sammy UN55C6400
    Onkyo TX-SR875
    Velodyne DPS-12
  • Willow
    edited January 2005
    the great debate which is better. Try one of those cables to see if will allow you to change the speaker setting. I use coax for my dvd I use coax to a toslink converter for my dig cable ( I only have 1 coax on my receiver). I prefer the coax. It's up to you giver a try and see what you prefer and most of all it may allow you to set the center to what size you want.
  • Dannieboiz
    edited January 2005
    I tried coax as well as optical. they both give me the same feature but I haven't really sit down to actually listen yet since the last time I tested it I only crabbed some regular RCA cables to test it, sounded pretty good though. Will try some more once I get everything mounted..... I'm still waiting for an answer for this thread . Any of you can help?
    Sammy UN55C6400
    Onkyo TX-SR875
    Velodyne DPS-12
  • Willow
    edited January 2005
    yeah right your room issue, I'm not sure I have a hard time with my rears they are not at the right spot as my couch must be against the back wall and my stands are not tall enough..but thats my prob.
    Back to you I still do not know why you cannot set your center. what if you change the settings of your mains ? can you then change the setting for center ?
  • Dannieboiz
    edited January 2005
    my fronts are set to large, I have no setting option for my rear it stays default as small as well.
    Sammy UN55C6400
    Onkyo TX-SR875
    Velodyne DPS-12
  • Willow
    edited January 2005
    what receiver are you using ?
  • Dannieboiz
    edited January 2005
    using an HK AVR500
    Sammy UN55C6400
    Onkyo TX-SR875
    Velodyne DPS-12
  • Willow
    edited January 2005
    tried downloading the manual but my system at work won't allow me
  • Dannieboiz
    edited January 2005
    strange, did you download it from ?
    here
    Sammy UN55C6400
    Onkyo TX-SR875
    Velodyne DPS-12
  • Mjr7531
    Mjr7531 Posts: 856
    edited January 2005
    Not at all, on the contrary, I think it's invaluable(spelling?), there is much more LF than we normally think.
    As for digital cables, it's sending 1 and 0, not much there you can improve or lose.
    I've used the worst RCA interconnects possible and still had great sounds, It's all gimmicks.
  • fireshoes
    fireshoes Posts: 3,167
    edited January 2005
    Psshh....there is definitely a difference betwen optical cables. I heard it! ;)
