Metal strip on LSi15 ? Do you use it.
tapeshc
tapeshc Posts: 135
edited January 2005 in 2 Channel Audio
Due to some recent changes to my 2 ch. setup, I want to use single speaker cable instead of Bi-Wire or Double run.
I have never used those metal strips that came with my LSi15 to connect Bass & Trebel connectors.
Have you used them or have any alternative that you have found better.
Any opinions or suggestions ?
Thanks in advance.
Tapesh
Post edited by tapeshc on
  • Frank Z
    Frank Z Posts: 5,860
    edited January 2005
    If you don't want to use it just use a short length of speaker wire from the bottom posts to the top. Badda Boom, Badda Bing!
  • okiepolkie
    okiepolkie Posts: 2,258
    edited January 2005
    You will not want to use the metal strips that came with your LSi's.
    An alternative would be to use good speaker wire to run from the top posts to the bottom post.
    If you are using banana plugs to connect from the amp to speaker, then use either bare speaker wire or wire with spades on the end to connect the top to bottom posts.
    If you are using bare wire or spades from the amp to speaker, then you can use banana plugs to go from the top to bottom posts.
    Depending on the gauge speaker wire you are using, you can strip a few centimeters of insulation off the wire and run it from the bottom to the top(or reverse) binding post. I would try this last since you would have a good amount of bare wire, which oxidizes faster and also is exposed for possibilities of shorting out the wire.
    edit: Frank beat me to it while I was typing
    Tschüss
    Zach
  • tapeshc
    tapeshc Posts: 135
    edited January 2005
    I will be using spades on speaker wire, as I am not very confident about Banana Plugs loose contact.
    So I think I will go with Some good speaker wire.
    Gauge, I think 14 should do it.
    Another thing that was bit surprising was that LSi top post only serve tweeter not mid range woofers, as I was expecting.
    I am not sure if thats normal or its only LSi.
    Tapesh
  • Frank Z
    edited January 2005
    Unless you are planning on disconnecting your speakers on a regular basis skip the spades, banana jacks, etc. All you are doing is adding another connection that you don't need. Bare wire into the terminals is all you need.
  • tapeshc
    tapeshc Posts: 135
    edited January 2005
    I fully agree with you on this, very few people believe this but I do believe that less connector means better signal.
    I always use bare wire, unless untill cable I am using is factory terminated.
    Banana Plugs - they are never tightly secured so I dont use them, I know it may sound ridiculous to some but thats me.
    Even with spades or bare wire I use AQ wrench to secure them tightly, believe it or not, bass does get better after you tighten them.
    Thanks for responding.
    Tapesh
  • Frank Z
    edited January 2005
    Your welcome........now where's my dollar?:D
  • 2+2
    2+2 Posts: 546
    edited January 2005
    Hey, when did the price go up? I thought it was only a penny for your thoughts....and no I dont want your nickel or your dime!! ;)
    System 1: Martin Logan Vantage, Rotel RC 1070, B&K Reference 200.2, Music Hall DAC 15.2, Yamaha 2300
    System 2: LSi15 w/db840, Marantz SR8400, Rotel 1080, RM6800 (C&S), Sony X2020ES
    System 3: LSi7, Yamaha SW215, Music Hall Maven, Music Hall MMF CD25 w/627opamps
    System 4: RTi100, Harman Kardon AVR 230, Panasonic DVD
  • jmierzur
    jmierzur Posts: 489
    edited January 2005
    And connect the speaker wire from the amp to the bottom speaker terminals.
  • Joey_V
    Joey_V Posts: 8,586
    edited January 2005
    Hey guys,
    What's wrong with using the stock metal strips on the LSi?
  • Frank Z
    edited January 2005
    Nothing at all but some folks feel that a wire jumper improves the sound quality.
    VR3 Posts: 28,820
    edited January 2005
    Alright, you seem to have a reason for most all data you spread...
    so... :o
    WHY!?!
    I can see it would be easier to connect, but... is that the only reason? Or is there some sonic wonder...
