Buttkickers: Added Value or Distraction?
PolkThug
Anybody have any experience with these? Do they get you more into the movie, or are they more of a gimmick that seems cool at first, but then becomes fatiguing?
Thanks,
PT
Thanks,
PT
Post edited by PolkThug on
LIMITED time with 4 bass shakers, limited because as you said/asked, seemed cool at first but kind of got annoying. The ladies loved it, lol.
the buttkickers are a better quality and may be better.
Mine were installed on the couch frame, I bet if they where installed to a platform or floor joist it would be better.
Madmax had some of the Clark system units and loved them.Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
Thanks for the reply, that's kind of what I thought. My friend is thinking of getting the Aura bass shankers, but he hasn't got to try them out anywhere.
I bought 4. Currently they sit all wrapped up ready to get shipped back. Never did install them as my base is so good now I didn't really see a need for them let alone the added cost of another amp.
I bought them on a whim due to a good sale price but just don't see the need and the fear they may be more distracting then not.If...
Ron loves a film = don't even rent. -
I just purchased 4 aura bass shaker pros and a 250 watt plate amp from parts express. Mounted them to my couches and added some 1x4 support and they are decient. I only use them on movies and i think they are pretty cool. originally i had a psw 350 and they assisted it but when i purchased my svs pci 20-39 they aren't as noticible but for 250 bucks its cool to see the reactions on peoples face when they feel them.System:
Toshiba 51h83 HDTV
Yamaha HTR-5660
Carver AV-405
Pioneer DV-578A-S
Comcast HD cable
RT1000i's
RT35i's
CS400i
F/X300i's
SVS PCi 20-39 -
At the Bose setup at Epcot, they have atleast 50 bass shakers between 4 benches to cover up the fact their sub SUCKS big ones....
I didnt like it at all... was very annoying- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
