Calibrating question......again
Meeks32
Meeks32 Posts: 330
edited January 2005 in Speakers
Alright, Im a little confused here on the proper way to calibrate. I have a HK230 & the manual says to -15 on the dial when calibrating with the ezset, so I am asuming you set it to -15 also when setting it manually. Now when I do this my channel levels are up to around +7 & +8 when using the DVE disk. Ive read that you dont want to boost it that much & to try to keep it closer to 0. So what should I do, do it like the manual says & keep the levels that high, or start at 0 for the FL speaker & turn the volume up till it reads 75db & then calibrate the rest from there?
Post edited by Meeks32 on
