LCD problems?
opus
opus Posts: 1,252
edited January 2005 in Electronics
So what does burn in look like?
I have a 14 mo. old Hitachi Lcd 50V500A. Today I noticed that when the picture is light you can see smudges on both sides of the screen. Obviously it is more pronounced in hd than sd and also appears on dvd's. They are where the bars would be if watching in 4:3 but they are not solid like the bars. They are irregular shaped and maybe as much as 1" wide and run vertical for 50 % of the screen.
Here we go. Don't laugh but they are shaped like tall, blurry, fuzzy, grey totem poles.(go ahead and have fun with that).
Any ideas? Is this burn in? I could post at HTF but hate to deal with all the Hitachi haters that seem to hang out there
......thanks kevin
The Flea rig
Hitachi 50VG825 LCD
Rotel RSP 1066 (pre) :)-flea market
B&K St-202 (mains)-flea market
Carver M 200t (x2) (center and surrounds)-flea market
Blu-Ray..PS3 (dvd player)
Polk RTA-11t-flea market
LsiC, Fxi30's
Dual SVS PC-Utra's (1 port blocked) thanks MikeC78
Behringer Feedback Destroyer
-flea market
AudioAlchemy DDE v1.0 DAC-flea market
Cambridge Audio Azur 640 CDP-flea market
Signal Cable and Kimber Kable
Post edited by opus on
  • Frank Z
    Frank Z Posts: 5,860
    edited January 2005
    If it's still under warranty, have it looked at by an authorized repair facilty. Generally burn in is going to have a very distinct pattern or shap that corresponds to a particular image that has been displayed for a long time. Unless you've been watching a lot of boring Totem Pole videos, I'd venture to guess that it's not burn in.:)
  • gregit
    gregit Posts: 284
    edited January 2005
    I may be wrong but I thought LCD was immune to burn-in?
  • Frank Z
    edited January 2005
    You are correct sir.
  • gregit
    gregit Posts: 284
    edited January 2005
    Opus....FYI-
    "LCD technology is not susceptible to burn-in, which is actually uneven aging of a display's phosphor. LCD TVs are liquid crystal-based, not phosphor-based, so there is no surface to burn-in. LCD TVs do exhibit a phenomenon known as "image retention" that occurs when bright objects have been left onscreen for an extended period of time, but this effect is not permanent."
  • beardog03
    beardog03 Posts: 5,550
    edited January 2005
    my computer moniter is starting to do this..
    The guy a BB said it was a signal motor (?)
    or pixels that are going out...
    Probably neither but they say it`s probably fixable...
    sorry I`m not much help, but I hear that it`s pretty common
    I`m taking it in tommorow, I`ll let ya know what kind of
    bull junk they try to feed me.....
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • opus
    opus Posts: 1,252
    edited January 2005
    Thanks to all replies.
    Did a little more research and find these smudges are a common problem that in most cases, mine included, go away after the tv is warmed up ( 30-40 min.).....kevin
    The Flea rig
    Hitachi 50VG825 LCD
    LsiC, Fxi30's
    -flea market
  • PolkThug
    PolkThug Posts: 7,532
    edited January 2005
    LCD's CAN develop problems that look like burn-in from static images. However, they are a LOT more tolerant than plasma or CRT.
  • beardog03
    edited January 2005
    my monitor is a samsung 191t...
    It has "smudges" in a couple of places...
    I`ve had it about a year ...year and a half maybe..
    I only have a repair warrenty, but I could have sworn I got the replacement one...:(
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • jeremie
    jeremie Posts: 246
    edited January 2005
    Please refer to this thread, many users have your same issues.
    http://www.avsforum.com/avs-vb/showthread.php?threadid=351829&highlight=50V500
    Receiver Yamaha 3070 *Emotiva xpa5 * Behringer iNuke 6000dsp *Monster Cable HTS 3500 -- line conditioner * Panamax 5300 * Apple 4K * Panasonic UB820 * JVC NX5 * Silver Ticket thin bezel 120”
    LSIM - Fronts 707 * Center 706c * Sides 702 * Rear 703 *FP RC85i * RP RC65i * Sub (2) SI HT18
  • jchas41
    jchas41 Posts: 84
    edited January 2005
    Get your TV serviced! I have the same TV and had the same problem, the smudges came and went with no real pattern. This is a defect and there is a bulletin on Hitachis service site. The only fix is screen replacement, my repair guy found the bulletin and fixed the screen immediately. Hope this helps.
    My Set-Up:
    Sharp LC60E88UN- Display
    Yamaha RX-A2020- A/V Receiver
    Pioneer Elite BDP-23FD Bluray Player
    Toshiba HD-A2 HD-DVD Player
    Velodyne DPS-12 - Sub
    Polk RTi8's- Fronts
    Polk CSi5 - Center Channel
    Polk FXi A4's- rear surrounds
    Monster HTS2600 Line Conditioner
    PS4
