tweeter phasing
barryboy
Got some new tweeters with black/white-black and grey/white-black wires. Lost instructions as to + or -. Can you help?
Want to be sure of proper phasing. Dont quite trust my hearing with smaller tweeters.
Actually hope to remove the small factory wires and solder 16 guage wire but want to be sure.
As long as there are tests in schools there will be prayer in schools.
Post edited by barryboy on
Follow them back to the crossover is the only way I found when I did the driver in one of my M12s. I had it out from the time I ordered it and forgot which was which. As for the replacement of the internal wires it took a lot of time and no big improvement. After the signal gets dispersed from the crossover the wire runs are short. It all adds up with other tweaks but this was a big job IMO for the out come. Think of it this way also add all those smaller wires up and you get the larger gauge.Chris
