Shpongle
Airplay355
http://www.shpongle.org/index.php?menu=music&subpage=255
like the flute? try the saudate part II clip. i think its really awesome. try some of the other clips too but don't expect mainstream anything.
Post edited by Airplay355 on
This is some of the best recorded music I have heard...
All of the songs Airplay has sent me is recorded crazy good... with tons of sound effects, instruments, bass, soundstaging...
ALL OF IT, you *must* check it out, especially the song Airplay is talking about above...
Highly recomended!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Are you Shpongled?
Wow, I think I'm having flashbacks man.
Good stuff. -
