Speaker Jumpers
On another thread ( can't recall which one ) someone told another person to not bother bi-wiring or bi-amping BUT to get rid of the jumpers on his terminals. Anyone know why you shouldn't use them ?
Sony STRDA-5000ES
Sony TA-N110 X 2
SONY CDP-CX205
SONY CDP-CX400
JVC XV-FA902SL
JVC AV-65WP74
JBL PB12 ( Sub )
POLK RTi-12 (Mains)
POLK CSi-5 (Center)
Infinity US1 x 4 (Rear surrounds)
Sony TA-N110 X 2
SONY CDP-CX205
SONY CDP-CX400
JVC XV-FA902SL
JVC AV-65WP74
JBL PB12 ( Sub )
POLK RTi-12 (Mains)
POLK CSi-5 (Center)
Post edited by Tropic-Al on
cheap metal strips sound bad, replacing with good speaker wire will sound better, that is the thought.Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
Thanks. So if I'm currently using bananas on my bottom two terminals, how do I jump the top terminals? And also are the factory jumpers on my speakers considered "cheap".Sony STRDA-5000ES
Sony TA-N110 X 2
SONY CDP-CX205
SONY CDP-CX400
JVC XV-FA902SL
JVC AV-65WP74
JBL PB12 ( Sub )
POLK RTi-12 (Mains)
POLK CSi-5 (Center)
Infinity US1 x 4 (Rear surrounds) -
You replace the stock (cheap) jumpers with new ones made of high quality speaker cable. You run the new jumpers just like the stock ones, from the bottom posts to the top posts. Use spades on the jumpers if you use bananas for your speaker cable or bananas on the jumpers if you use spades on your speaker cable.Political Correctness'.........defined
President of Club Polk -
There's a reason you're the POLK MASTER[/COLOR
Thanks!Sony STRDA-5000ES
Sony TA-N110 X 2
SONY CDP-CX205
SONY CDP-CX400
JVC XV-FA902SL
JVC AV-65WP74
JBL PB12 ( Sub )
POLK RTi-12 (Mains)
POLK CSi-5 (Center)
Al, this is one of the more bizarre of the old audiophiles' tales which continue to float around. Speaker manufacturers who spend a lot of time and money designing and developing a good product don't then sabotage their own speakers by using a "cheap" connector which "sounds bad". Any reasonably conductive piece of metal has no discernible effect over the 2-3" involved.
Ever try it John? Nah, I didn't think so.Political Correctness'.........defined
http://www.cobaltcable.com/product/bi-wire_jumpers.htm something like this...Never kick a fresh **** on a hot day.
