High efficiency bookshelf speakers
Early B.
Early B. Posts: 7,900
edited February 2005 in 2 Channel Audio
I'm looking for a pair of highly efficient bookshelf speakers to go with tube gear. My criteria include:
1. less than $500 used in very good condition
2. gotta have some decent bass (around 50 Hz or less)
3. looks are fairly important
4. will consider DIY
5. a good resell value
Any speakers come to mind that fit these criteria?
"God grooves with tubes."
Post edited by Early B. on
  • Loud & Clear
    Loud & Clear Posts: 1,538
    edited January 2005
    Early,
    Your profile still indicates your earlier, solid state gear.
    Two Channel Setup:
    Speakers: Wharfedale Opus 2-3
    Integrated Amp: Krell S-300i
    DAC: Arcam irDac
    Source: iMac
    Remote Control: iPad Mini
    3.2 Home Theater Setup:
    Fronts: Klipsch RP-160M
    Center: Klipsch RP-160M
    Subwoofer: SVS PB12NSD (X 2)
    AVR: Yamaha Aventage RX-A2030
    Blu Ray: Sony BDP-S790
    TV Source: DirecTV Genie
  • Early B.
    edited January 2005
    That's my HT system. I have a separate 2-channel setup.
  • gatemplin
    gatemplin Posts: 1,595
    edited January 2005
    I'll throw out some suggestions for you. A popular DIY kit for tube gear is the Adire Audio HE10 http://www.adireaudio.com/TextPages/HE101PageFrameText.htm
    They also have the high efficiency HE12 and KIT281. I think they look good but other people probably dont. DIY also has a fairly low resale value.
    Another DIY option is full range drivers like those from Fostex and Lowther (expensive).
    http://www.lowtherloudspeakers.co.uk/homeindex.html
    http://www.fostexinternational.com/docs/speaker_comp/line_up_1.shtml
    There are also lots of HE vintage speakers from companies like Klipsch, EV, and Altec.
    Graham
  • Early B.
    edited January 2005
    Thanks, gatemplin.
    I think I'll try a DIY full range design using the Fostex FE166E drivers.
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
    edited January 2005
    Early,
    Double your budget and buy some SDA SRSs. Of course, you'll be needing a larger bookshelf to hold them :p
    They're on the order of 92 db efficient and a 4 ohm nominal load. All of my tube gear drives them very well (35 to 75 wpc). I was never overly impressed with the bass response and extension of the PRs until I drove them with tube amplification - now I am. Plus, you won't have to concern yourself with resale value - you'll never part with them. :cool:
    Mike
  • hoosier21
    hoosier21 Posts: 4,427
    edited January 2005
    www.decware.com has some nice FR designs, here is one available http://www.decware.com/HDT/hdt.htm
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • waylyn5945
    waylyn5945 Posts: 18
    edited January 2005
    Have you looked at any of the speakers from Definitive Technology (DefTech)?
    Wayno
  • Danny Tse
    Danny Tse Posts: 5,206
    edited January 2005
    I highly recommend the Energy Connoisseur C-3, soundstage.com's 2002 Budget Leader Award winner. Here's another
    review.
    Now that Energy has introduced a new line (the Connoisseur Reference series), the C-3 is now available for less than $500.00/pair. I have seen them as low as $250.00/pair brand-new from authorized dealers.
  • madmax
    madmax Posts: 12,434
    edited January 2005
    I'm going to be trying the DecWare HDT's in about 3 to 6 months if you want to wait that long for a review. Actually I've read the HDT's are a great deal and have superior sound with no shout, whatever that means. I'm sold on them without even a listen but that doesn't mean much. Check out this review.
    http://forum.audiogon.com/cgi-bin/frr.pl?rspkr&1100567900&read&3&4&
    You can build them yourself for about $110 supplies plus $300 for the drivers. (or $168 for drivers if you want to get by cheaper).
    madmax
    Vinyl, the final frontier...
    VR3 Posts: 29,648
    edited January 2005
    :D
    This is gonna be fun.
  • marker
    marker Posts: 1,084
    edited January 2005
    One word I can't believe someone else hasn't already suggested-
    Klipsch.
    They would go great with tubes with their horns.
  • pjdami
    pjdami Posts: 1,894
    edited January 2005
    Lot's of great choices here already mentioned. I add one that hasn't been mentioned and is "different" and unique.
    Triangle speakers. Titus or the bigger Comete fit your price range and good efficiency. I've heard the Titus on Audio Research tube amp gear and it was very good. A little weak in the bass though; perhaps the Comete would fare better.
    Lots of good reviews on audioreview.com and Stereophile Recommended B speakers. Definitely worth a demo if you can listen to them on some tube gear.
    http://www.audioshopper.com/audiowaves/TRIANGLE.html
  • organ
    organ Posts: 4,969
    edited January 2005
    Don't really know what the resell value on these would be but you should be able to find them for under $500. Check out the Klipsch RB-35 from their Reference line. At 96db/w/m, they are super efficient. I've got the tower version and they sound fabulous with tubes. The cheaper ones would be the RB-25 and 15. http://www.klipsch.com/product/product.aspx?cid=659
    Maurice
  • steveinaz
    steveinaz Posts: 19,546
    2 93dB @ 1watt efficient choices under $500 (new):
    1. Energy C-3
    2. Athena AS-B2
  • George Grand
    George Grand Posts: 12,256
    Small to medium sized B & W's. I have a pair of DM-550's here in the house. While they're not likely to displace either the Amazing's or the AR-9's, they are not offensive in the least. I was hitting them pretty good the other day with a Carver M-500t power amp (NAD 1020A pre), they sounded great, went down fairly low, and they're ported, so fairly efficient.
    George Grand (of the Jersey Grands)
    VR3 Posts: 29,648
    Just wanted to let you guys know Early B is getting Fostex FE166E in a vented enclosure ;) and shouldnt cost much more than 300-350 ;)
  • madmax
    Oh no! You are not building them are you?? :D
    madmax
    VR3 Posts: 29,648
    :D
    See thread - Early B: Off Topic
  • madmax
    Off Topic? RU getting old or something? Didn't see it.
    madmax
  • TheReaper
    TheReaper Posts: 636
  • madmax
    OK, I saw that when it first went up but couldn't figure it out. I guess he could call it an "Ampra B". :)
    madmax
