Any Solar pool heater installers?
disneyjoe7
disneyjoe7 Posts: 11,435
edited March 2024 in Clubhouse Archives
I thinking of installing this myself as I can’t get over the profit margin or the **** work you pay for sometimes, foolish or not. I will be installing this system at the other end of the house as my pool equipment is on the north end of the house. My plumping will be under the pool deck so the check valve & 3 way valve or installed horizontal and then straight into ground. Where should the vacuum break be installed what I have read is on the feed pipe about 4ft up. Can this be installed at the collector somewhere?
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR
Post edited by RyanC_Masimo on
  • goingganzo
    goingganzo Posts: 2,793
    edited January 2005
    by the dish washer like mine is lol
  • dorokusai
    dorokusai Posts: 25,577
    edited January 2005
    First and foremost, are you primarily interested in a HT pool setup or a 2CH only setup, because that will determine alot of things.
    If you don't add some Panamax Surge Protection to your collector than you may be asking for trouble.
    Also, I would highly advise that you upgrade your check valve to a PS Audio Check Valve, why? well, just because they have a better contact % than a regular check valve.
    If you are going to enter the substrate and beyond, you better look into some Perfect Surface Copper conduit, as opposed to the oh' so out of style Single Crystal Copper conduit.
    If you want some crazy high flow rates, definetly look into the Silver line of conduit, as it has a flow rate that will blow your mind.
    DJ, I hope this was real helpful....and good luck in your project.
  • disneyjoe7
    edited January 2005
    Huh,
    Nothing of this help thanks.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • dorokusai
    edited January 2005
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
    edited January 2005
    Doro is definitely on the right track here. Sub the job to him and kick back!
  • disneyjoe7
    edited January 2005
    You're HIRED :D
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • disneyjoe7
    edited January 2005
    Doro,
    Thanks for the links at least one company would place the vacuum breaker at the collector panel. So I too feel good about placing it there. The company I buying this from used the vacuum on the feed side about 4 ft up, since this is going into the ground to come up at the other side of the house I was confused.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • dorokusai
    edited January 2005
    Cool, I figured one of those links would help. Have fun!
  • amulford
    amulford Posts: 5,020
    edited January 2005
    Steve, put the vacuum break at the collector. Then put drains at the low points on the inlet and outlet right above the takeoffs for the bypass (right on the collector side of the block valves). Be sure to plumb it in a way to allow free drain and be able to blow the system down if you choose to winterize.
  • disneyjoe7
    edited January 2005
    I owned a pool for 7 years here at my old house, so I can say I never winterized :D
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
