which center for rti100
ximen
ximen Posts: 8
edited January 2005 in Speakers
I have rti100 for a while. I would like to have a center speaker now. The polk website recommned csi30 but I can't find it anywhere. Any suggestion on that? How about a infinity alpha center whic is on sale for $129 only. THanks.
By the way, A dumb question: I currrently connect composite audio out (Left and Right) from dvd player to receiver. Did l loose 3 channel? so center speaker will get nothing if I use this connection? My receiver has 5.1ch input but the DVD player has only two audio out.
Post edited by ximen on
  • faster100
    faster100 Posts: 6,124
    edited January 2005
    Well if you want it to somewhat match, stay with polks... csi30 can be found in the used market online..
    far as the dvd setup, you need to use a digital coax or optical cable to get surround sound in 5.1 and above.. the inputs for 5.1 are for dvd audio/sacd player hookup.. your dvd player should have analog left/right outputs plus a digital out, if it doesnt you wont get 5.1 or any sound other then 2 channel analog
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • okiepolkie
    okiepolkie Posts: 2,258
    edited January 2005
    What receiver do you have?
    What DVD player do you have?
    A CSi30 or CSi40 would be good matches for your RTi100's. Both are difficult to find used at reasonable prices.
    Don't get the Infinity. It will not be timbre matched to your system.
    Tschüss
    Zach
  • ximen
    ximen Posts: 8
    edited January 2005
    The csi30 is hard to find. How about the csi3? It's old kenwood receiver. No optical connection but has one coaxial connection. Never used before. Is the coaxial cable same as the cable for TV?
    I am thinking about upgrade the receiver under $300. I am looking for onkyo or denon, which brand is better for polk?
  • okiepolkie
    edited January 2005
    I've seen a lot of people prefer Denon, but Onkyo is fine too. Check www.ecost.com or www.pcmall.com if you don't mind refurbished receivers.
    The coax in is a digital input.
    Does your DVD player have a digital coaxial output, or an optical output?
    If your DVD player does have it, then you will want to get a rca digital coaxial cable to get Dolby Digital.
    How much are you looking to spend for the center channel. I might know where to get a CSi40 if you are interested.
    Tschüss
    Zach
  • ximen
    ximen Posts: 8
    edited January 2005
    I am looking to spend around $150 for the center and $300 for the receiver. Thanks
  • EricH
    EricH Posts: 140
    edited January 2005
    Online used, CSi30's are usually around $100 to $120. 40's are $200 to $240.
  • gmorris
    gmorris Posts: 1,179
    edited January 2005
    Is your receiver an old Pro Logic, or is it Dolby Digital? If you don't know, look at the little logos on the front of the receiver, it should say either "Pro Logic" or "Dolby Digital", or maybe "AC3".
    Bob Mayo, on the keyboards. Bob Mayo.
  • Airplay355
    Airplay355 Posts: 4,298
    edited January 2005
