Jolida going to triode mode!
madmax
I've been reading about mods to turn the Jolida 302 in to a triode mode machine. Cut wire going to pin 4 and add a 2 watt 100 ohm resistor between pins 3 and 4 of each tube.
Simple and a lot of people say it is a good mod. On the other hand I read an article which says you can do this but you must also make other mods to make it work properly which includes a bunch of circuitry and use of different tubes.
I'm going to give the simple mod a try. Worst case I could always switch it back.
madmax
madmax
Vinyl, the final frontier...
Post edited by madmax on
madmax forget that. take it to warp speed !
i have no idea what triode mode is.PolkFest 2012, who's going>?
Good luck, hope it works out.
I had unhooked the Dynaco for about a month while I went on a movie kick. I plugged her in a couple of days ago and hooked up the SDA2's and man my memory is short cause I forgot how much better music is with that combo.
Even though it sounds great as is, I really need to rework the Dynaco.SDA-2a, Anthem Pre-2L, Anthem Amp 1, MF A324 DAC, Rotel RCD1070
Senn HD650 Cardas, Mapletree Audio Ear+ HD2, Kimber KS1030, Bel Canto DAC2, M-Audio Transit, Laptop. -
Oh yeah, wait until Maurice reads you're going triode.
I'm a little confused. There is triode mode, then there is class A, then there is SET... Then there is true triode mode vs push-pull triode mode.
