wall surround better then towers?
Hi,
I am currently running RT600i on my fronts and cs245i center. I am in the process of setting up my surrounds. I found some R30 towers at a really good price. cheaper then the current FXi bi/dipoler wall surrounds.
Are the wall surrounds better? WOuld I loose out on good surround sound if I went for the R30s instead of surrounds?
The deal on the r30s is too good to pass up. But i dont want to make a mistake and regret it. Anyone here have towers for surrounds, how do they sound compared to wall surrounds?
thxs.
thxs.
Polk RT600i's
Polk C245i Center
Jbl surrounds (need to find F/X300s) info anyone???
Harmon Kardon AVR80
Sony Processor SDP-E800
Toshiba DVD SD-1200
Sony Minidisk MDS-JE320
Monster 400MKII Interconnects
--all protected by PANAMAX 1000+
Polk C245i Center
Harmon Kardon AVR80
Toshiba DVD SD-1200
Post edited by ralph76 on
I'll sell you my two right channel FXi30's for $90 shipped.
BTW, have you set up your PM box?Tschüss
Zach -
Its all setup now. check your pm.
thanksPolk RT600i's
Polk C245i Center
Harmon Kardon AVR80
Toshiba DVD SD-1200
--all protected by PANAMAX 1000+ -
what difference does it make between L/R and two R's... isn't each speaker identical to another??
Not on fx series speakers, it has a woofer and tweeter on opposite sides.. and its a triangle shaped speaker, so the woofers need both be outside or inside to work right.MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC
