which subs and amps 2 use
Systems
Systems Posts: 14,872
edited January 2005 in Car Subwoofer Talk
Xtant or Arc Audio
2 xtant-x1001
2 xtant-x602
OR
arc audio-xxk4150
arc audio-xxk2500
and which subs
4-12" eclipse titanium
Or
4-12" ID Max-d4 v.3
Testing
Testing
Testing
  • Joelsbass
    Joelsbass Posts: 637
    edited January 2005
    of those i'd go with xtant and ID Max
    for the subs take a look at the Adire Brahma
    www.adireaudio.com
    MacLeod: I guess youre lucky Polk has such lax hiring standards.
    Josh: Damn skippy!
  • MacLeod
    MacLeod Posts: 14,358
    edited January 2005
    DEFINITELY go with the Xtants. They rule!
    I also agree with Joel with the ID MAX. Awesome subs. Put out tons of volume and still sound great!
  • SamSagaZ
    SamSagaZ Posts: 321
    edited January 2005
    the adire brahma is better than the MM2124, right?
  • Joelsbass
    edited January 2005
    the adire Brahma is in a much different league from the Polk subs.
    Bear in mind that this sub costs almost $400, and with a different brand name would probably go for $600.
    Josh: Damn skippy!
  • MacLeod
    edited January 2005
    Yeah, the Brahma is in the league of IDMAX, W7, and H2. Real heavy hitters there.
  • SamSagaZ
    SamSagaZ Posts: 321
    edited January 2005
    well, ok.....
    i would buy maybe later an brahma.....
    i dont know why i buy 2 mm2124 instead 1 brahma :(
  • Joelsbass
    edited January 2005
    brahma will cost you more... more for the sub and more for the power... for a 10" you'd need at least 1000w...
    that calls for 1/0ga wire for the total system, a LOT of dampening, upgraded alt, and probably a second battery to make sure you have an electrical system that can handle it... (with a good amp you're looking at like an 80-100A draw...)
    Josh: Damn skippy!
  • swerve
    swerve Posts: 1,862
    edited January 2005
    I got me a 15' ****... so i'm fenna be ballin. Sam you could get this for 435 shipped buddy! that's pretty cheap-o-riffic if you aks me homey.
    -adam
    cats.vans.bag...
  • MacLeod
    edited January 2005
    I dunno. You could get a MM2124DVC for about $150. Itll handle 800 watts and sound great.
  • SamSagaZ
    SamSagaZ Posts: 321
    edited January 2005
    well i already buy an pair of MM2124 to use in parallel at 800W
  • MacLeod
    edited January 2005
    Trust me, youll be fine.
    The MM2124 isnt a mega bass sub that will pound your windshield out but it is one of the better sounding subs on the market.
    Just wait til you get them hooked up and powered. I assure you that you wont regret your purchase.
  • SamSagaZ
    SamSagaZ Posts: 321
    edited January 2005
    yeah :) i want to receive my amps soon!
  • swerve
    swerve Posts: 1,862
    edited January 2005
    Sam i was pertyy happy with my 2124's and i didn't even power then correctly. so yea enjoy your thump homey!
    -adam
    cats.vans.bag...
