Brand new R50's Blown Tweeter?
BrettSelinsky
BrettSelinsky Posts: 49
edited January 2005 in Troubleshooting
I just got a brand new set of R50's and I was playing them at under 1/2 throttle and I think one tweeter blew. Funny thing is if I turn the volume up to 1/2 it will come back on every once in awhile and then go down again. I only hyad them one day. Im running them with a Sony STR-De945. Could this be the problem?I also do not notice that much difference in sound quality from the cheapo panasonics I had before the r50's. They didnt blow above 1/2 volume.:(
Brett Selinsky
Denon 3805
Denon DVD/CD
Crown ProAmp
JVC VHS
RTi70's Front
CSi5 Center
R50's Rear
DefTech Sub
Post edited by BrettSelinsky on
  • danger boy
    danger boy Posts: 15,722
    edited January 2005
    sounds like it might be a loosely connected wire to the tweeter. that can happens sometimes... so it may not be blown after all.
    Contact Ken @ Polk customer service.. they will help you out.
    P.S. I had a friend who kept blowing his tweeters too.. with his 140WPC Onkyo receiver.. over and over again.. I think he played it to loud.. even though he sweared he didn't.
    I don't know if this is your same problem.. doens't sound like it. sounds like a loose wire to me.
    good luck.
    PolkFest 2012, who's going>?
  • BrettSelinsky
    edited January 2005
    Thanks for the help. If the reciever isnt puttig out enough juice how much juice do I need. Is that Sony the reason they dont sound all that much better than the cheapo speakers.
    I thought Sony was good until I started reading this forum and noticed Sony was not mentioned very much. And now it may be the cause of a blown tweeter.
    What do I look for in good sounding recievers. Is THD that important. I guess I want the best sound I can get for the money but I dont know what specs to look at. This would be for HT and music.
    Brett Selinsky
    Denon 3805
    Denon DVD/CD
    Crown ProAmp
    JVC VHS
    RTi70's Front
    CSi5 Center
    R50's Rear
    DefTech Sub
  • danger boy
    edited January 2005
    if you want to stickwith a Sony receiver.. look into their high end gear called their ES line. there are a few people in here who love their Sony's.. but they are mostly the higher end ES line of receivers. ES stands for elevated series.
    Some people claim that Sony's don't sound that great with Polk speaker. I can't vouch for that. It's been years and years since I owned a Sony receiver.
    Folk in here seem to like Denon, Onkyo, Yamaha, some Pioneer Elite, I use a Marantz with external amps. Not a whole lot of love for Marantz in here either. ;)
    You can get into the entry or mid level lines of most of those without to much $$.
    But yeah, you may have to replace your Sony with something else? Also.. you can score some great deals on used receivers and save a bundle. Look for demo models, open box, refurbished.
    I looked up your Sony. says it's 110WPC built in 2000. so it's not very old.
    F1nut Posts: 51,783
    edited January 2005
    It's a cheap **** receiver, it'll give you cheap **** sound. I don't think you blew the tweeter. As mentioned, most likely a loose connection inside the speaker.
  • BrettSelinsky
    edited January 2005
    Thanks Again. I am doing a lot of reading and learning in the forums. HK sounds like a popular one. I actually think they sound pretty good in HT but its the music that doesnt impress me at all. what do you think about just adding an amp. Allthough I dont know if my sony has amp hookups?
    Brett Selinsky
    Denon 3805
    Denon DVD/CD
    Crown ProAmp
    JVC VHS
    RTi70's Front
    CSi5 Center
    R50's Rear
    DefTech Sub
  • danger boy
    edited January 2005
    you Sony would need to have what's called pre outs. for you to hook an external amps.
  • Tour2ma
    Tour2ma Posts: 10,177
    edited January 2005
    The production of sound after a volume increase followed by a slow fade out says "crossover component problem" to me, like a capacitor is leaking the HF back to the amp.
    I think this is a return or a call to Ken situation...
    More later,
    Tour...
    Vox Copuli
  • BrettSelinsky
    edited January 2005
    Well I removed the tweeter and hooked it up direct to the reciever and got nothing. Took the tweeter out of one of my rt15i and it worked fine. So it must be blown. BY-BY Sony! Just dont know which reciever to get? Thanks for the help.
    Brett Selinsky
    Denon 3805
    Denon DVD/CD
    Crown ProAmp
    JVC VHS
    RTi70's Front
    CSi5 Center
    R50's Rear
    DefTech Sub
  • Tour2ma
    edited January 2005
    Not a peep out of the R50 tweet, huh??? Can't figure the fade out you mentioned earlier...
    No matter... contact Ken Swauger about sending in the tweeter for a replacement. Depending on your dealer it may be a warranty replacement.
    More later,
    Tour...
    Vox Copuli
