Room size - how much of a difference?
brody05
brody05 Posts: 329
I have moved into a new house that has a much bigger room than previously as well as higher cielings, it seems my bass just isn't giving me the same old 'feeling'. The cieling is 3 meters high and the room is 6.2 meters by 6.3 meters and I am running a pair of RT3000s in the front of the front preouts, a 1200 watt twin 10 inch enclosed sub and a PSW 650 running in the rear off the rear preouts, I would estimate that I have about 80% of the bass I used to have and have increased sub volume from -7 to +4.
Is it just the big room that stops me from feeling the sound waves with the LFE stuff, I am also running the 3000 subs in reverse phase.
Any advice would be appreciated.
Brody
Post edited by brody05 on
