Amp upgrade
I-SIG
I-SIG Posts: 2,243
edited January 2005 in Electronics
How much of an upgrade would I be making if I went from my Parasound HCA-2200 to a Musical Fidelity A-300cr?
Are these MF amps bridgeable? I'm thinking no since they are dual mono.
Wes
Link: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
Post edited by I-SIG on
  • steveinaz
    steveinaz Posts: 19,538
    edited January 2005
    Personally, I would consider it a move sideways. You wouldn't be gaining anything, but you would be losing output power....I'd think twice about it Wes.
  • I-SIG
    I-SIG Posts: 2,243
    edited January 2005
    That why I was thinking a source upgrade would get me farther. Thanks, Steve!
    Wes
  • steveinaz
    edited January 2005
    Absolutely, look at:
    Ah! Njoe Toeb
    Creek CD50MKII (this is what I would buy)
    Jolida
    Rega Jupiter
    to name a few....
  • hoosier21
    hoosier21 Posts: 4,413
    edited January 2005
    it might be cooler in your room with the MF
    Ask me I would go for the MF
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • jmierzur
    jmierzur Posts: 489
    edited January 2005
    If you are looking to upgrade, I noticed a Sim Audio W-5 for sale.
    There is also a Sim Audio W-5 LE on audiogon.
  • I-SIG
    I-SIG Posts: 2,243
    edited January 2005
    Anyone know if these are 4-ohm stable in bridged operation? They have a 2-ohm rating so I'mthinking they may be.
    Wes
  • steveinaz
    edited January 2005
    I think you're wasting your time upgrading the amp. You're gonna have to spend about 5 grand to get any noticeable performance increase over that Parasound.
    Hell, spend $1,500 on a great CD Player instead--you'll get much more bang for your buck, and the change in qulaity will not be subtle...
    Better yet:
    Cambridge Audio Azur 640 (used as a transport)
    Bel Canto DAC or MSB full nelson DAC
    Thats a killer rig....
  • I-SIG
    I-SIG Posts: 2,243
    edited January 2005
    Thanks, Steve. I'm most likely gonna end up with a source upgrade, but I'm still asking. :)
    What do you like about the Creek 50 MarkII player so much over the AH! player?
    Wes
  • steveinaz
    edited January 2005
    Just a very solid unit that is getting rave reviews from everyone. It uses a DVD transport to eliminate jitter--smart idea. I think it made stereophiles' "A" list too, which is never a bad thing.
    One reviewer said "...it's about as close to perfect as digital gets..". Not a bad accolade for an under $1,300 CDP.
    I'm a bit weary of tubed sources...I dunno, I like alot of detail and from what I've read on the topic, most reveiwers mention "slight loss of detail." I grew up on solid state and personally prefer its sound...HOWEVER, you should listen to tubed CD Player, you might like the effect.
  • I-SIG
    I-SIG Posts: 2,243
    edited January 2005
    I was concerned about that after my experience with the tube preamp. I think my AA DLC preamp is a fairly warm piece of gear as is, but with better details than the tube pre. It seems a tubed source might bring the downside of tubes back into play for my gear a listening pleasures.
    Thanks again.
    Wes
