new rti4 speakers
scotteads
scotteads Posts: 2
edited January 2005 in Speakers
i just received my new rti4's. i loved them in the store (tweeter), but they dont sound as good in my home. they sounded awesome in the store. I am also playing some old kenwood speakers at the same time. that may be my problem. i am also running them on a old receiver, which i plan to get a yamaha htr 5740 soon. dont get me wrong the speakers still sound good, just not as good as they did in the store. i am using them as my rear speakers now. i plan on rti6 or rti4 for the front, csi3 for center, and a sub. maybe once i complete my system it will all blend well together. any ideas?
Post edited by scotteads on
  • okiepolkie
    okiepolkie Posts: 2,258
    edited January 2005
    Welcome to the Polk forum.
    Try them as your fronts for a while by themselves to see how they sound. It may take a couple of days before you start to notice very much with them. I'm not sure about the RTi series, but most speakers sound a little better after a few hours of playing(this is called break-in).
    A few questions to help you/us out:
    What receiver are you using to run them now?
    What receiver was running them in the store?
    What size room do you have compared to the listeninig room at Tweeter?
    What settings do you have your current receiver set on?
    Tschüss
    Zach
  • hoosier21
    hoosier21 Posts: 4,418
    edited January 2005
    maybe they just need to break in, new speakers need some time to lossen up and sound right
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • scotteads
    scotteads Posts: 2
    edited January 2005
    i'm not sure the model number of my receiver, but it is about 12 years old. it was a great one at the time. it is plenty of wattage. the receiver in tweeter was a yamaha, but i'm not sure the model #. maybe i should find out?? that is why i plan on upgrading to a decent yamaha, unless someone has a better recommendation. the room at tweeter was bigger than my room, so i thought it would fill the room more.
  • Willow
    Willow Posts: 11,234
    edited January 2005
    I would agree....try to hook them up as your mains only do not hook up your others right now. How old is your speaker cable ? maybe time for new stuff. Are your connections nice and tight ? Clean? Just go through your cd's and play a mix of your fav stuff let your ears break in
  • PolkThug
    PolkThug Posts: 7,532
    edited January 2005
    Hi Scott,
    Keep in mind the RTi4 is a small bookshelf speaker. I've got some old Kenwoods as well, that put out more bass than my RTi8's, but the crisp, clean sound of the RTi8's mid and tweet makes it a superior speaker.
    Regards,
    PolkThug
  • Mark of Cenla
    Mark of Cenla Posts: 35
    edited January 2005
    I bought my RTi4 speakers last summer. I really like them, and I am pretty picky. Give yourself time to get used to them, especially if they sound a lot different than what you already had. Peace.
    Mark Wellman ><>
    "Let he who is without sin cast the first stone."
