Sony Projector Upgrade
BakedWafer
BakedWafer Posts: 48
edited May 2009 in Electronics
I will be upgrading a Sony Projector, which is too dim to make it workable anymore. I was wondering if you guys could give any recommendations. I am looking for something that is > that 3000:1 contrast ratio and > than 700 lumens. I am looking @ the Marantz VS4 (12,000) but it's a little out of my budget.
Regards
Post edited by BakedWafer on
  • okiepolkie
    okiepolkie Posts: 2,258
    edited January 2005
    What is your budget?
    Also, what are you going to do with your old projector?
    Tschüss
    Zach
  • BakedWafer
    edited January 2005
    My budget is 4,000 - 7,000. I am going to sell the old projector.
  • okiepolkie
    edited January 2005
    Either one of these would be good projectors. The Domino is definetely the better of them. They all have the TI HD2+ chipset.
    BenQ PE8700 @ approx-$4200
    Sim2 Domino 30H @ approx-$7000-$8000.
    Here is a quick comparison to some DLP projectors within your price range.
    Projector Central
    Hope this helps.
    Tschüss
    Zach
  • Frank Z
    Frank Z Posts: 5,860
    edited January 2005
    Which model are you currently using? I've got an HS20 and it's a great PJ.
  • BakedWafer
    edited January 2005
    VTP - HT11 or something, I am not home right now so I can't check.
    I am thinking about this:
    http://www.thetwistergroup.com/store/customer/product.php?productid=TDPMT800%20C00784&source=dt
    for an upgrade. The one I got is 600:1 contrast ratio 1000 Ansi Lumens and does not have DVI/VGA. Let me know what you guys think.
  • Frank Z
    edited January 2005
    Make sure you audition any DLP pj before you buy it to ensure that you or your family members aren't affected by the rainbows. It's not a real common problem, but some folks do get headaches from it.
    As far as DLP systems, I've read lots of really great reviews for the Infocus 7200.
  • okiepolkie
    edited January 2005
    From what I know, the color wheels with more than 5 segments(colors) do a pretty good job of eliminating most of the rainbow effet.
    The Toshiba looks like a good projector. It also seems to carry a good price with it too.
    Are there any places that will let you try out a projector and trade it in(kind of like Crutchfield)?
    Tschüss
    Zach
  • Frank Z
    edited January 2005
    Wheel segments and wheel speed make a difference, but to some it doesn't mean a damn thing. Some folks simply can't stand the effect.
  • okiepolkie
    edited January 2005
    Frank Z,
    You are right that it is a good idea to try them out first. That is why I asked if there was anywhere you can get a high quality projector to try them out. Fifteen minutes in a store probably won't let your eyes catch everything to help you make a great decision.
    IMHO, I have liked the picture a DLP produces better than an LCD.
    Personal preference, I guess.
    Tschüss
    Zach
  • Toxis
    Toxis Posts: 5,116
    edited January 2005
    well, typically if the color wheel spins at 9800rpm or faster, the rainbow effect cannot be seen by anyone. The effect was only a problem with 6800rpm (I think that's right, 6000-7000 range). Plus, most DLP's have 6 segments which is dual red, dual green & dual blue...
    If you're looking for a good projector in your price range, I'd HIGHLY recommend the Sim2 Domino 30. If you want to save a few bucks ($3500ish) go with the Hitachi PR-TJ100 (can't remember the letters... damn model numbers!).
  • Sherardp
    Sherardp Posts: 8,038
    edited May 2009
    hi baked. the way i see it you only have 2 choices with that 4000 budget, the jvc hd3500, it has 800 lumens but it has a native contrast of 30000;1 so itl look brighter in a dark room than any pj with a lower contrast .Next if you need a light cannon go for the epson 6500 then you can use the leftovers for cool adons
    And it's JVC HD350 by the way, which is equal to JVC RS10.
