Tundra best fit?
outlander
Hi,
I have a 2000 Toyota Tundra (access cab). I was wondering what would be the best / easiest fitting Polk's to replace the 4 stock speakers. And is there a big improvement going from the db to momo series?
Thanks!
O
Thanks!
O
Post edited by outlander on
Have you tried going to Crutchfield.com, entering the year and make of your vehicle. If not, try that and it will tell you exactly what sizes will fit. Not only that Crutchfield carries both models.
http://www.crutchfield.com/S-PH741NyuMC5/cgi-bin/autoinfo/autoinfo.asp?vehicleid=0&typeCH=home&vb=Y&lp=%2FS-PH741NyuMC5%2Findex%5F20050110b%2Ehtml%3F%26id%3D0%26vehicleid%3D0&cm_re_o=TkB_zkEzM*kwufEzM*ctzfubflFYgzyMoney Talks, Mine says Goodbye Rob!!!! -
yes, there is a big improvement from the momos to the dbs. but both are great for the price
Agreed. Both are pretty much the best speaker you can get at their particular price point.
I think the DB and Momo sound pretty close but the Momo is more detailed and has a little more midbass.polkaudio sound quality competitor since 2005
