Audio experiance any good on e-bay
faster100
These audio experiance tube pre's on e-bay from hong kong any good? http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=14974&item=5742608462&rd=1&ssPageName=WDVW
MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC
Post edited by faster100 on
They have been on there for years and the feedback looks good. Never heard or seen one though.
I think russ' "pink" pre was a audio experiance.. This one takes 1 6x4 rect tube and 3 12ax7's i think they are called for output... I may pick one up to try with this parasound amp... and keep the parasound pre also to compare the 2MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
I was looking at that and amazed with the price and their claims. I would like to have some opinions on the Audio Experience since I am looking for an entry level hi-end pre-amp for my system.
My friend has this Audio Experience pre tube amp. It is just as good, if not better, than his Audio Research pre. He recently changed out the tubes and now it's awesome.
Excellent value for the money. I almost bought one. Looks great, too.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Thanks for the info, EarlyB
Read the great feedback from the guy who is selling it.
The only drawback is if you ever have warranty/repair issues. Otherwise, go for it. Also check audiogon. Sometimes you can find them used for $250 - $300.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
I think i plan to get one of these real soon, all the tube pre talk and after getting a nice parasound amp.. i think i want to try tubes in the pre stage.. well seeMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC
